Suzuki diff ratios
Suzuki diff ratios
I am half way thru swapping manual escudo diffs into an automatic. i have done the back but not front, so currently have different ratios in the front and back. would it be ok to drive around for a few days in 2wd like this?
Re: Suzuki diff ratios
Yes, if you have free wheeling hubs (unlocked) and you are in 2WD, the front diff is not turning at all. Even if you don't have free wheeling hubs you still wouldn't have any problem as long as your in 2WD.
- Rotazuk
What are you doing with your auto diff heads ?
Could be interested in a swap ..
Chris
Chris
