There are a few little mod's that I'm planning for the truck to make it that little bit more capable and fun to drive so am starting this build thread to record them...
I picked up a set of half worn Swampers for a good price that should give me some better clearance under the diffs. First need to make some room to fit them. Starting with the rears found a bit of rust getting in the way of the new rubber. Marked up a new guard shape:
And quickly lightened the truck, removed rust, opened up the guards in one big movement with a 230mm Angle grinder (remember this is a bush truck not show car project):
Plenty of room in there now but needed to move the diff back about 100mm. Could have done a spring reversal but instead went with upgrade to longer 60 series springs and a spring reversal. Considering my options here as problem is mounts on my chassis are the older (smaller & narrower bush and pin sizes) and 60 series stuff is the later model bigger pins & bushes... on the hunt for some spares now...
