im pretty new to the whole 4x4 scene so ill try do as much as poss myself...
feel free to laugh/add comments etc
this is my toy...
http://www.offroadexpress.co.nz/images/ ... .sized.jpg
so far it has had... newer motor/box(just a shitty 2L-t),4.55 LSDs front/rear, front axle shifted forward,10" shocks in front/rear, 35x12.5" BFG's,longer shock mounts, 50mm body lift, shitty rear lift shackles blah blah, probly more but not worth mentioning...
have just recently finished rebuilding front axle with new everything inc. diff seals/bearing etc...
not much of a job for some of you but it took me ages,
my plans are as follows which will be getting tackled from middle then rear then front,
my dual t/case adaptor has arrived and im just waiting on my 2nd tcase to turn up so i can start pulling it to bits and install the bits for my crawler box...
once thats done ill start on my custom g/box crossmember to be rid of the horrible standard thing...
then i will mount a disk/calliper setup on rear of my t/case for my handbrake..
moving onto the rear ill be putting a wider rear surf axle in to get rid of my tyre rub issues,
on the axle there will be a disk conversion(still to decide on items to use)
i have a set of falcon rear springs to go in with sum long travel ranchos which will be mounted...
thinking of ditching my rear LSD and getting an auto-locker but ill see what happens...
in the front there will be my rear springs with ranchos with a hysteer conversion and possibly wider hubs...
so thats my plan...
so far the t/case is getting started...
it out for a start
ill post up pics as the project progresses so stay tuned...
matt
