Toyota v8 adaptor plate
TOYRANGE
Post by TOYRANGE »
hey guys ive recently had a adpator plate made which allows the 1uzfe v8 auto bellhousing to be used and bolted to a hilux or supra type gearbox if anyones interested i can get these made by the guy who made mine. cost $250. pm me if anyones interested.these made from steel
Maddog
Post by Maddog »
sounds like a boodly good deal,now if only i had the rest of the money to do a conversion. :P
So have you done this conversion ?
What year hilux did you put it in or going to put in?
Does it work for autos.?
how hard is this to do.?
96 Bighorn Irmscher Lwb 3.1 - standard
previous 4WDs
93 Hilux surf
92 Isuzu Bighorn Irmscher 2.8 ,SWB, 122k,lifted, other mods
91 V6 Surf
TOYRANGE
Post by TOYRANGE »
Right.Im putting it up to a supra box and just using it as a 2wd.The plate came off a 1ufze v8 and 2wd hilux 2003 combo(installed in a 88 ).apparently these will fit supra/hilux boxs.Most wreckers in auckland sell these motors for around $1500 with wiring/airflow meter etc.Im not to sure if you would need a plate to bolt your auto up to the v8 because the 1u v8s usually only have autos behind them.A mate of a mate has put one into a 88 4wd lux and he reckons its pritty nuts.Hope thats of some help.
Maddog
Post by Maddog »
Thanks Toyrange
Hmmm....One day.....yes .. one day. :lol:
previous 4WDs
93 Hilux surf
91 V6 Surf
DJ
Post by DJ »
Hi guys
having done this conversion a few times in 4wds I found its not as straight foward as just getting an adpator plate and bolting on a gearbox please consider what flywheel and clutch you will use as all Toyota V8s available are autos and toyota has not made a flywheel that interchanges.Then theres the computor problems, as the V8 computer is wired (??) up to the auto and a few accesories just to make life interesting. The only joy I have had getting around that problem so far has been by using a Link Plus computer at great expense ($1800 appox plus fitting). Engine mounts are not differcult but the hand brake is interesting. Cooling with all Toyoto's is a problem ( just ask the stock car guys) But with all these small differcults sorted out wheel spinning the rear bags at 80 ks in 3rd is fun and will impress even a RR owner. Although I dont want to use this forum to sell my product you have started the ball rolling (ok Mike ??????) The price for just the gearbox adpator from me is $175 plus freight Special to Offroad express members. PM email
cheers DJ
all the above problems plus many others I have sorted and have proven to be correct and relable.
TOYRANGE
Post by TOYRANGE »
okay a toyota gt4 (3sgte) flywheel bolts straight on to the 1u and there are h/d clutches available for these.these flywheels cost about $150.My friend who has done alot of these 1u conversions has found that the one with the link management actually runs worse that the one with just standard management.He is an auto electrician and has had no problems wiring them up with the factory loom maybe he could explain to you how.$175 jeez I shoulda bought mine from you. :D
DJ
Post by DJ »
:oops: as I said I have tried different aproaches to these problems and have found RELIABLE and safe solutions. Toyota gt4 flywheels DO NOT bolt straight up, give it a go find out (like I did ) There is some people sloting the holes or drilling them larger to make them fit but they have , more than likely, never seen a flywheel expolsion caused by flywheel run out. I for one like it to be right first time and the metal around the holes is getting rather thin after drilling or slotting.The heavy duty pressure plate off the shelf are set at 950 to 1000 presure units ( the correct term for clamping pressure excapes me at the moment) I get these new units reset to 1500 as set at 1000 units they WILL slip when giving the truck the big hurry up. there is no difference to pedal travel or feal.As for the computor its programable there fore if its running like shit, then before rubbishing it check out the human element Having said that Im looking for a cheaper system.
have Fun
cheers DJ
Maddog
Post by Maddog »
so .....what do both of you know about if you can do this conversion wth a 4wd auto.?
Are you able to get an adaptor or is it easier to use the auto that comes with a 1ufze & modify the trans tunnel & driveshafts ? Can that even be done?
Or is it just easier to chuck in a small chev V8 & ditch the cpu side of things.?
previous 4WDs
93 Hilux surf
91 V6 Surf
Guest
Post by Guest »
Yes go with the chev a bit heavier than a alloy V8 but a lot less trouble and heaps more torque.
DJ
Post by DJ »
Hi
I have driven small and big chevs auto and manuals, carb and TBI and yes a whole bunch more useable torque, parts easily found cheaper by far. But very heavy in the front, handling like a foreshore claim you never know whats going to happen next. Have driven a Holden V6 Auto conversion and by far the best with no mods needed to the suspension, but my own driver ( Surf ) I'm sticking to to the tried and proven Supra conversion its the less hassles and easiest and compared to Toyota V8 and is more than equal when driven in anger.
Cheers DJ
co builder of 454 Mud Bug as seen in Rotorua Winch Challange Photos
DJ
Post by DJ »
I just remembered
You can get any motor to fit (with in reason ) and get it preform and handle, you are only limited by imagination and MONEY
syko
1uz-fe into vzn130
Post by syko »
i have just fitted a 1uz-fe to an auto surf. it took a bloody long time to do the electronics as half the wires had been cut and needed to be traced back to their sensors and identified. i used the toyota ecu, but you would have to do this if fitting a link system anyway. i also had to "piggy-back" the surf ecu for the electronicaly controled trans, this involved a lot of splicing etc. to get the engine as far back as possible i used the original torque converter which is shallower than the v8 one. this meant having to get the bellhousing modified (about 3" removed). this was done by some local engineers but was 1mm out and broke 2 flexiplates. the bellhousing has since been sent "conversion components" and trued up. so far so good! to get enough space for the radiator to stay in its factory position i had to move the trans and transfer back 35mm. this meant shortening one driveshaft and lengthening the other. same for trans shifter and 2-4wd lever etc. this job was done in a workshop for a customer and cost a lot of money but the end result is brilliant! they should come :shock: from the factory like this!
syko
hilux rear disc brakes
Post by syko »
this is what i was actually looking for when i found this site! anyone know of a kit available in nz? found some usa ones but not much use to me here! i want to fit them to a nz new ln106 that spends its winters up to the diffheads in papa mud ruts........
syko
Post by syko »
dunno where my subject went but its "rear disc brakes for hilux"
Return to “Toyota”
