I finally got my Series 2 all going. I had to pull the master cylinder off to clean it out and free up the piston. I then had to free up the throttle and adjust the idle. Bung off the rear brakes as there is none on 1 side and the other side leaks.
Took for a drive around and had a good time but didnt go to far as I was low on fuel and had a miss but thats all been sorted.
I will try and post some pictures later.
Next on the list is some rear brakes does anyone have any???
Im talking about the complete unit from the line from the centre of the diff to the drivers side (piston, shoes, everything). The otherside I can just fix as its a leak.
then rust to be taken out and get the indicators going and then its wof time
