replacing rear sliders with fixed
For all Nissan related topics
Heath
Post by Heath »
So is it just a matter of removing the sliders and replacing with rubbers and fixed panes?
Mate has a high top with sliders and wants them replaced with fixed. does any fixed lwb saf/pat window fit?
Should he attempt to do it himself or get a panel beater to do it? Not sure of his Mech skills or the tools he might have at his disposal.
bobrocket
Re: replacing rear sliders with fixed
Post by bobrocket »
Have got a lwb with fixed windows, its an 91 AD model GQ, had a quick measure for you, inside edges of the rubber, it's not exact just close (ish) the windows are a bit of a funny shape.
770mm top horizontal
840mm bottom horizontal
450mm center vertical
meece4x4
Post by meece4x4 »
most Saf LWB ive seen have solid rear windows, as far as i'm aware (and may be wrong ...not that up on Whales) the low roof Patrols and the High roof Saf's should be the same up to the roof height, maybe the factory 7 seaters where fitted with the rear sliders only??. so the easiest way would be to just replace with sliders with solids from a wrecker, the rubbers a one piece affair that should be pretty easy to fit at home if you have ever fitted an old skool windscreen with a bit of patience. :wink:
curly12
Post by curly12 »
meece4x4 wrote:most Saf LWB ive seen have solid rear windows, as far as i'm aware (and may be wrong ...not that up on Whales) the low roof Patrols and the High roof Saf's should be the same up to the roof height, maybe the factory 7 seaters where fitted with the rear sliders only??.
Aussie built ones had the sliding windows
flyingbrick
Post by flyingbrick »
I had solid windows on my safari. They are easy to remove but a pita to re-install.
Totally recommend finding the glass and taking it to an expert to get done.
Return to “Nissan”
