D.B's GQ Shorty
Shane
Re: D.B's GQ Shorty
Post by Shane »
pipe is 3" pre-bent mandrel bend(from auto bend)after triming back a few times to fit,I cut slits in it then bent them in to fit the V clamp ring(approx 2.75")the ring is quite thin so I got a sheet metal place down the road from work Tig it up to reduce the risk warping,I would have stuffed it for sure if I tryed to weld it.turned out pretty good,I'm happy with it anyway.
this gives me about 15mm clearance to fire-wall,well be wraping down pipe
Shane
Re: D.B's GQ Shorty
Post by Shane »
suzolla
Re: D.B's GQ Shorty
Post by suzolla »
To get a tight bend, could you use a 2 1/2" short radius bend sch 40, the OD is 2.875" or 73mm with a 5mm wall thickness.
Tim
Heath
Re: D.B's GQ Shorty
Post by Heath »
Almost some room for an intercooler there...
Shane
Re: D.B's GQ Shorty
Post by Shane »
Heath wrote:Almost some room for an intercooler there...
Dont need intercooler in the south island Heath :D
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
Cheers Shane, good pic's!!!
Chuck a couple up when you have the dump pipe fitted :D :D
Not starting mine untill next week, just playing with idea's and sourcing parts :D
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
What manifold gaskets are people using??
I Just got off the phone to Nissan and the gasket comes in 6 separate pieces at $32each ($213+gst for all 6)
Or an after market kit for $30 total for all 6.
I thought I had read somewhere that some of the after market gaskets are arse??
badnuz
Re: D.B's GQ Shorty
Post by badnuz »
my limited knowledge tells me get genuine, they are solid as apposed to a honeycomb style... better heat resistance and longer life :)
suzolla
Re: D.B's GQ Shorty
Post by suzolla »
Hi Pete,
Check with RS Industries and see what he thinks about using the T10 graphite as an option, although maybe a bit difficult to cut.
Tim
darinz
Re: D.B's GQ Shorty
Post by darinz »
DieselBoy wrote:What manifold gaskets are people using??
Don't waste your money on aftermarket. Use factory! In most cases just keep the old ones and reuse them and they'll out last the motor. i just kept burning the aftermarket ones out and then got some second hand factory ones which then lasted for several years.
Don't forget to restrict the oil feed to about a 2mm hole (as has been said) or you will stuff the seals in the turbo and it will smoke like a mother! Also make sure the oil return is as big as possible but at least 1/2" and is as vertical as possible and the fitting in the sump is above the oil level. Any blocked or restriction in the oil return will cause oil to force past the seals (again stuffing them and causing smoking)
Also it is 100% import that oil feed is from the top and as vertical as possible. Any angle could again caus oil to be forced past the seals and cause smoking.
I'll be impressed if you get 17psi at 2000rpm! My T3 (safari kit) could only get 14psi at 2000rpm (21psi max at 2700) and that was with an auto and line locking it so absolute max load.
PigFmr
Re: D.B's GQ Shorty
Post by PigFmr »
Shane wrote:
DieselBoy wrote:Keen for some dump pipe pic's Shane :D :D
Rodger..I'll go get the D/cam
shane
on my 2nd turbo manifold now 1st one work well log style,now have a nice set of extractors 6 into 4 into the turbo,wiv two 2inch pipes coming out of the turbo into a collecter wiv 3inch dump pipe took a while but the dump pipe took a while to fit up to look nice,running a ct26 wiv garret internals now smaller comp wheel,also had to clock my turbo aswell to get oil feed and drain right, this mod i shud of dne 5yrs ago on the old tart gave her a new life,
vince
Heath
Re: D.B's GQ Shorty
Post by Heath »
shane
vince
PICS!!!
Fakey
Re: D.B's GQ Shorty
Post by Fakey »
shane
vince
Arrrgh :evil: (Insert Skid grammer rant here ) :lol:
Didn't barbie drive a jeep??
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
Got the last of the stuff required for the Turbo fitment :twisted:
So far the tally is 8)
:arrow: DSR Turbo - Currently away getting re-balanced and Garrett bearings and seals fitted
:arrow: DSR Manifold - Has had the luuurve and ready to fit :D
:arrow: Nissan Mistral Airbox - Hacked and chopped and 3" inlet and outlet fitted, mounted complete with K & N and plumbed into snorkel
:arrow: Nissan TD27T injector pump - currently in the shop along with my TD42 pump getting mixed and matched and rebuilt to Turbo spec's with boost compensator aneroid etc
I have been slack with pic's, but there ain't much exciting to see yet :D :D
Heath
Re: D.B's GQ Shorty
Post by Heath »
DieselBoy wrote:Got the last of the stuff required for the Turbo fitment :twisted:
Fark... bet your wallet is smoking soon. It'll be a quivering mess in the corner with all that $$$ activity.
nzhunter
Re: D.B's GQ Shorty
Post by nzhunter »
Oh dude chuuuurrr can't wait to see how it goes.......
Mint whos doing this for you??
Shane
Re: D.B's GQ Shorty
Post by Shane »
took a few goes to get the V clamp lined up,each time I did the clamp up it pushed the exhast off center(try yours on the bench before you weld the exhast to it)
Make sure you trial fit the manifold.I had to grind a small bit from No 2 runner so the nut would turn.
just little things really,no real stress just a matter of getting it rite
Lynx
Re: D.B's GQ Shorty
Post by Lynx »
DieselBoy wrote:Nissan TD27T injector pump - currently in the shop along with my TD42 pump getting mixed and matched and rebuilt to Turbo spec's with boost compensator aneroid etc
Hey DB, thats defiantly the best thing you can do with these pumps, and it sounds like its going to be an awesome install.
Best of luck man
Cheers Daniel
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
nzhunter wrote:Oh dude chuuuurrr can't wait to see how it goes.......
Hahaha, they are under strict instructions not to build me a race pump, so they are just giving it the basic rebuild it was badly in need of, plus adding the aneroid and setting it up on the bench to run 15psi max. Should be a solid set up :twisted: :twisted:
Turbo Diesel & Automotive are playing with the pump for me.
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
Pic's = 1,000 words :twisted: :twisted:
Engine bay
Room for future intercooler
Oil feed
Sump oil drain
Dump pipe
Injector pump with TD27 aneroid
Goes pretty good now :mrgreen: :mrgreen: :mrgreen:
UBZ
Re: D.B's GQ Shorty
Post by UBZ »
DieselBoy wrote:Goes pretty good now :mrgreen: :mrgreen: :mrgreen:
And it sounds farken awesome doing 3rd low 4wheel skids up a hill
:twisted: :twisted: 8) :mrgreen:
Mud Hog
Re: D.B's GQ Shorty
Post by Mud Hog »
Whats your air box from? I like the install very tidy.
GU patrol 35s ect.
gimmemud
Re: D.B's GQ Shorty
Post by gimmemud »
You never seem to do things by halves do ya! :twisted: Rad!
wopass
Re: D.B's GQ Shorty
Post by wopass »
that looks chur as now ow!!
Shane
Re: D.B's GQ Shorty
Post by Shane »
very nice,what boost you running at?
when crusing at 100kph what psi do you get?(no load just cruise)
hope to get mine going this weekend,I keep getting called away for work :( ,also had 5 days in nelson.
Shane
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
Shane wrote:very nice,what boost you running at?
Shane
The pump allows it to do 15psi max. It drops the fuel out at about 4,000rpm and the manifold pressure drops back.
Its doing about 3psi at 100k's on 33's.
The wastegate actuator has a very soft spring in it so I have pretty much blocked it off altogether. The gate was opening at about 8psi. I will fit a boost controller when I get round to it.
The Injector pump won't allow it to over boost, as the boost is controlled by the fuel.
It could do with some more fuel off idle, but thats about it.
Edit: 5psi at 100k's :D
DieselBoy
Re: D.B's GQ Shorty
Post by DieselBoy »
Time for some new doors, the originals don't have any straight panels left on them :lol: :lol:
The drivers door got smashed on the 42 Travers back when the track was more entertaining, the passengers door got hammered around the wires loop at some point :D :D
New doors prepped ready for paint, rust holes in both doors repaired :mrgreen: :mrgreen:
Red base coat, getting ready to add the Charcoal:
The finished result with Charcoal base and blingy clear coated :D :D
Have to be patient and wait untill Monday night after work to fit them :cry: :cry: :lol: :lol:
wopass
Re: D.B's GQ Shorty
Post by wopass »
put them on tacky and go for a hoon in the swamp!!!!
:lol:
callum007
Re: D.B's GQ Shorty
Post by callum007 »
then re clear coat them. added swamp bling
Shane
Re: D.B's GQ Shorty
Post by Shane »
doors look mint,you going to flick the rest of truck or give it a good buff?
Have you got simex's for it?think I saw a pic some were with tripple blocks on
got mine running last week,just need to finish off a few things.
drives much nicer than the other turbo set up,boost much lower down.exhast temps lower also.
at 100kph is 7-8psi,the old set up was 3-4psi which I think is to low.I havent changed the injecter pump/air cleaner from the old set up as I wonted a direct turbo comparison.I have blocked the waste gate also(8psi no good)max boost is 20psi only done that a few times.have made a little boost controller for short term till I get a incab one.I'm going to set about 15-17psi as long as clutch holds.
Shane
