Tuff Truck style build up, Nissan Safari
skidtoy
Post by skidtoy »
building up my safari do do alot of rock work...got all the suspension into it this weekend. time to start the diff now cal cv's,box section up the front diff, locker...
when i put this on its side or smash the body up to much it will come off and im going to put a swb one one cut down to a xtracab style front with exo cage flat deck, anyway pics...
You Get That
Re: Tuff Truck style build up, Nissan Safari
Post by You Get That »
Im likeing the look of this, Any more specs?
Addicted to suzukis....
skidtoy
Post by skidtoy »
umm its a tired old 88 diesel safari
7inch lift Superior Engineering Superflex kit, 37x14.5r15 Maxxis Creepy Crawler, bodylift...building a Tuff Truck type truck so there is still alot of work to go into this, we are also building another truck the same spec as this but low roof and petrol.
Fakey
Post by Fakey »
Thought you were using 38s on it? :D
Didn't barbie drive a jeep??
skidtoy
Post by skidtoy »
was going to use 38inch Creepy's from the states but i now have a wheel supplier for 17inch alloy beadlocks so will be running the 37's for street use and some 4wd'n and 40inch Trepador sticky's for crawling...will be running Allied 4x4 rims from auz which are on afew trucks that compete in tuff truck.
DieselBoy
Post by DieselBoy »
skidtoy wrote:
when i put this on its side...........
Which won't take you long :shock: :shock:
Fawk rock crawling in that, it's COG is way WAY WAY to high :lol: :lol:
Any thoughts on dropping some lift out of it and cutting the guards to get the 40's under it instead?? Would make it go better :D :D
Would make an awesome sth island river truck like it is though!!!!!!
skidtoy
Post by skidtoy »
not worried bout it wanting to tip in anyway what so ever and no it wont be going lower because im building this to play in big rocks not the type of stuff you boys with 4inch lift will need to be skull dragged over...this truck is running same set up as mine and it goes pretty much everywhere.
if you need to to be dragged over car sized rocks give me a call and ill be happy to do it :lol: :lol: :lol:
MNC
Post by MNC »
You've got to understand DB's post though. Heaps of weight up high = tippy on sidelings.
Dont see many of the trials guys with high wagons but I guess that's not what you are building this truck for anyway. I'm guessing you take the family wheeling on weekends?
Alot of guys go SWB to improve ramp over angle which would get round the need to be so high.
Anyway, I like it. 8) Reckon I could use it to launch and retrieve the boat even on the flattest of beaches.
Looking forward to hearing more about the beadlock rims to. You do any steel 15x12" beadlocks?
Fakey
Post by Fakey »
Is that a cut down 70 series in the back of that last pic?
Heath
Post by Heath »
I like the fairlead on that wagon. :mrgreen:
turoa
Pyro Junior
Post by turoa »
Fakey wrote:Is that a cut down 70 series in the back of that last pic?
na its a cut down bunderra (prado). 80 series diffs, truggied out rear, 1uz, airshocks and 42" iroks
MNC
Post by MNC »
If there was an award for sharpest eyes on ORE it would go to you for sure!
Assuming you have seen that truck before?
skidtoy
Post by skidtoy »
MNC wrote:You've got to understand DB's post though. Heaps of weight up high = tippy on sidelings.
yea not into trails at all, i find it like watching paint dry but worse haha. i not a fan of shortys i think they look foot too short although a shorty body (well most of it)will end up on this chassis haha
not sure yet about Allied 4x4 beadlocks as it wont be until after xmas until we look at bringing them in to nz will most likely only be 15x8 15x10 steel around $1000.00 per set of 4.15x8 17x8 alloy around $1500.00 per set of 4
skidtoy
Post by skidtoy »
yea the blue toyota is a cool little truck...ummm if you call a truck on 42inch tyres little 8) 8) 8)
turoa
Pyro Junior
Post by turoa »
Ya its quite cool that thing
skidtoy
Post by skidtoy »
GotFlex
Post by GotFlex »
your truck is tough as!! i cant wait till NZ starts following the rest of the world and gets bigger trucks bigger tires!! good to see someone breaking the trend :)
wsr4x4
Post by wsr4x4 »
So where you planning on rock crawling around taranaki?
skidtoy
Post by skidtoy »
got a couple of places lined up just waiting for for the 1 of the other trucks to be rolling
skidtoy
Post by skidtoy »
GotFlex wrote:your truck is tough as!! i cant wait till NZ starts following the rest of the world and gets bigger trucks bigger tires!! good to see someone breaking the trend :)
thanks mate, yea i think the same thing a typical nz built truck just wont go where i want to.
wsr4x4
Post by wsr4x4 »
Come out with us sometime, ive got that surf that was on 37 creepys on 35s now.and a mate has that mat green v8 60 series. dunno about any rock crawling thow?
skidtoy
Post by skidtoy »
yea wilber was saying you boys have been down to his place acouple of times,he's a friend of my family my sisters partner has the $100 orange hilux parked down at the farm.
rokhound
Post by rokhound »
Interesting choice of vehicle. Will be interested to see how it goes. My pick is you will be sorting the truck cab out real early on as recovering flopped rigs in rocks is not the same as wallowing around in the mud, and with a COG up where that thing is, you will be flopping it a fair bit (assuming you are going hard out :wink: :P ).
Have you shaved the diff housings to gain the extra clearance? and what sort of gear reductions are you running? With a big ole bitch like her you are going to need the best part of 200 - 1 or you will be forever breaking shit through drive line stress caused by high rev's and instant loading.
I am not a fan of external bead locks as they only lock 1 side of the tyre, and when playing on rocks you are just as likely to blow an inside bead off, this is why I run narrower (8") rims on a 15.5" tyre.
Cool to see some one else who wants to play, shame your in the wrong Island :lol: :lol:
skidtoy
Post by skidtoy »
rokhound wrote:Interesting choice of vehicle. Will be interested to see how it goes. My pick is you will be sorting the truck cab out real early on as recovering flopped rigs in rocks is not the same as wallowing around in the mud, and with a COG up where that thing is, you will be flopping it a fair bit (assuming you are going hard out :wink: :P ).
went with nissan after playing with afew other makes of truck because of parts you can get and for there drivetrain. diffs are pretty much standard at the moment as the suspension has cost quite abit to get...but diffs are the next thing on the list to be done, well im starting on them now.
have been looking at 85% reduction gears for the transfer to help get it up over rocks. i do know what you are saying about external beadlocks but havent found them too bad so far on other things...if i have problems ill just put some internals in also as my mate has acouple of sets or staun 15inch internals.
haha mate no need to worry about it not been driven how it should, eveything i own gets a hammering...not much point in owning something if you arent going use it for what its for.
Kingpin
Post by Kingpin »
wow this truck is mean as!
time for a noob question: how much has it cost you so far?
isnapped.blogspot.com - my car photography site
www.lotuslimited.co.nz - LOTUS streetwear - my clothing co.
niblik
Post by niblik »
skidtoy wrote:http://www.youtube.com/watch?v=aI-QURNb-XI
sounds like a hilltop hoods soundtrack???
i likey!
skidtoy
Post by skidtoy »
Kingpin wrote:wow this truck is mean as!
just over 14g at this point including buying the truck which is pretty good when you look at the shit boxes with 4inchs of lift and fucked bodys for 10g on trademe. suspension is worth more than the truck and works AWESOME...!!! best thing i have spent money on drives over big arse rocks, logs...makes it nice and easy to change the oil also.
i dont think i would ever have a 4wd again with anything under 37's and the ground clearance this has, it makes things that used to be alittle hard a waste of time now even starting the truck up for.
skidtoy
Post by skidtoy »
i likey!
gota have auzzie music for auzzie style trucks haha
StreetClique
Post by StreetClique »
i likey!
Funkoars (dare i say it, better than hilltop!)
stealth
Post by stealth »
Mean truck i will be following this rolling developement
