indentifying a terrano clutch
For all Nissan related topics
grytvikken
Post by grytvikken »
Hi have an old terrano D21 2.7 turbo deisel that I am putting back together and I have found that I have misplaced the clutch pressure plate and was wondering if there are any means to identify a pressure plate off a turbo from one off a non turbo 2.7....
I have a wrecker that may have one but is not sure as he has pulled apart both a turbo and a non turbo.
This vehicle is just going to be used on a property and i anm not keen on spending $500 on a clutch kit for it if i can find a good 2nd hand unit. cheers
Nav2NV
Re: indentifying a terrano clutch
Post by Nav2NV »
I know you can get a normal duty and a heavy duty type for them but I'm not sure if there were any differences between turbo and non turbo.
If its only a farm hack (?or similar) would it really matter?
grytvikken
I have been told that it does and if I put a non turbo one in it will slip? It will be used to drive to and from town occasionally so reliability is a consideration
sibainmud
Post by sibainmud »
imo ,you're better off going new;
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Nissan/Clutches/auction-318389012.htm
Worth getting flywheel machined too.
Cheers.
long
Post by long »
Got both here outta a turbo terrano if u want them
grytvikken
how much
Damz
Post by Damz »
Got a turbo pressure plate and clutch disc you can have, LOTS of life left. Only replaced it because Im currently swapping engines and boxes between my navaras and DONT want to be pulling the farkin box out again anytime soon to replace a clutch...!!
You pay post and Ill get it to ya :wink:
Return to “Nissan”
