HJ45 longterm project.
dino
Post by dino »
I have an HJ45 that is pretty much stock standard which i am planning to modify/tweak as i can afford it/get around to it, so i thought id start a thread so i could ask a couple of question about various things.
I have a set of 33" buckshots on 10 inch rims which rub on the disc break calipers that ive put on it. should i change my rims for offset ones or will wheel spacers do the trick?
DMcCready
Re: HJ45 longterm project.
Post by DMcCready »
Depends on what are you going to be doing with it. Is it off road only or will you be trying to get a WOF?
How much do the rims hit the calipers? Heaps or a little?
There's gotta be some rocks round here SOMEWHERE!
what kind of 10" rims have you got
most of the readily available white spoke 10" rims are a negative 44 offset, and shouldn't really have any rubbing issues
what disc brake set up have you got :?:
dino
Post by dino »
used on the road to so will need to pass a WOF. local rural garage anyway which im sure would overlook spacers, im more concerned about the spacers being a week point. they dont hit the calipers by a lot but enough to make me want to do something about it.
unsure of rim make they just look like normal whitespokes though. discs are off my bj42 which had them fitted when i got it
is it front or rear callipers that are rubbing and are they cruiser callipers or something else?
dino
Post by dino »
front calipers, ah ill have to find tomorrow.
dino
Post by dino »
talked to previous owner and he reckons theyre cruiser callipers. i see on the SNR website that you can get spacers up to 3" wide, are these road legal?
kbjj
Post by kbjj »
From memory its 20mm max for a spacer, and 27mm for an adaptor, plus other criteria about stud length, locating and fixing.
Fakey
Post by Fakey »
Think its 6mm max for slip on spacers an 27mm max for bolt on both should be certed.
Do your calipers look like these? If youve got early cruiser ones they should look like the ones on the right.
Didn't barbie drive a jeep??
dino
Post by dino »
yea callipers same as ones on the right. would spacers put a significant amount of strain on my hub bearings? or in saying that it would be the same as offset rims wouldnt it?
muddy
Post by muddy »
It's a common problem - to do with the shape of the rim centres rather than the offset. The slip-on spacers are the easy answer. They work well, as long as your wheel studs are long enough. I think the legal requirement is at least 7 turns on the wheel nut. The skinny ones aren't too obvious to a WOF inspector and I never had any trouble with them, but I think they technically require LVVTA certification.
I've heard of some people grinding the edge of the caliper housing since it only needs about 3mm to get clearance and they've got plenty of meat, but I was a bit reluctant to do that...
niblik
Post by niblik »
muddy's on the money..
either get some slim slip on spacers and run the risk of non certification or grind the calipers a touch.
oh, and ya forgot the most important thing.
pics!
:mrgreen:
Fakey
Post by Fakey »
Fakey wrote:Think its 6mm max for slip on spacers an 27mm max for bolt on both should be certed.
As Nibs said pics are the key, your rims must be a strange offset. I used the bigger calipers (LN130 surf) on the left on the front of my 40 with 15x8s (-24) with no rubbing at all.
The smaller ones on the right are standard on the front of 70 series, hiluxs etc. They were my rear ones :D
dino
Post by dino »
thanks fellas think ill get sum slip on spacers and longer studs then. pics to come, but shes up on blocks in the shed @ the moment nd thats a bit like sending someone a pic of your kid in a hospital bed :lol: . does anyone know where i can get aftermarket cvs for this truck?
cheers deano
ClassicCruiserSpares
dino wrote:does anyone know where i can get aftermarket cvs for this truck?
Do you mean longfields? or just new standard ones?
longfields?
8) 8) 8)
dino
Post by dino »
im thinking standard ones, longfields are a bit pricey for me :(
dino wrote:im thinking standard ones, longfields are a bit pricey for me :(
http://www.trademe.co.nz/Trade-Me-Motor ... 510925.htm
I think jafas selling trailgear 4340 Chromoly CVs at about half the price of those TM ones, there was a thread up about Chromoly CV's on here a couple of weeks ago
unless you've got lots of horsepower, front diff lock, big tyres and driving like you stole it standard CVs should be fine in general
dino
Post by dino »
cheers sadam, ill send jaffa a PM.
yea your probly right, just thought id go for the better ones if the difference in price wasnt excessive.
dino
Post by dino »
After driving the 45 round pretty much standard for a while ive decided that i need more power :D had my mind set on a lexus V8 with cruiser gearbox, untill i read a thread about how crap they are in the water... now not sure but unsure of an alternative either. can anyone whos running a lexus put my worries to rest or suggest another plan??
Cheers Deano
Why not put a 350 in it? itll be a hell of alot easyier than a lexus.
Fakey
Post by Fakey »
350 for sure :mrgreen:
dino
Post by dino »
was opting for the lexus so i could use a cruiser gearbox and therefore keep my pto winch and also had a mate of a mate who could wire it into the 45s loom for me (apparently done a couple before). What are your reasons for preffering the 350??
The 350 will bolt straight up to your gearbox so you can keep you pto, they are alot easyier to wire than a lexus, they have alot more torque, and will cost shitloads less to put in.
I can help with the parts to fit the 350 if you do go that way ive got them sitting in my garage that i dont need anymore.
dino
Post by dino »
how much would i expect to pay for a 350? anything i should be looking for in particular when looking for a motor?
i understand there is no disadvantage in having a carburetted engine?
What are the parts that u have that are needed?
Cheers for the info fellas.
Ive got the front engine mount, bellhousing, clutch fork, flywheel clutch and pressure plate.
Not sure what a good 350 worth these days but i have seen some selling cheap on trademe.
dino
Post by dino »
would this bellhousing bolt up to a 5 Speed cruiser box? not sure what out of yet just know i wanto get rid of the 4 speed i have.
Pm me how much you want for the lot.
i take it the 350 would be more waterproof than the lexus?
Yes you could bolt a 5 speed onto the back of the bellhousing.
The chev is easy to make water proof .
Ill pm you. :D
Big
Post by Big »
ha but you'll have much more fun with a lex.. :wink: Yes the 350's have more tq BUT the lex will out scream a 350 hands down and thats what clears tahs.. my 5 cents wurth..lol :mrgreen: :mrgreen:
can you tell I''m a lex fan.. :twisted: and if you want more tq then blow it.. it'll blow a 350 outter the water if you do that AND it's injected..350's are not..
haw haw.. :wink:
