Hi.
I have a 1992 safari, 4.2 Diesel.
Had problems today with high oil pressure (just over 6) and oil light coming on.
With engine turned off oil press gauge sits on 4., when running, sitting on about 6, and hardly varying when the engine is revved.
Am inclined to think it is simply a guage/oil press sensor fault, but would be interested to know if anyone has any suggestions.
nissan safari high oil pressure
thanks for the replies...
will get a mechanical gauge and check for sure today..
is it much of a job getting at the sender unit?
also, am assuming on the safari, both the oil light and press gauge come off the same sender unit?? is this correct?
any good ideas on where to buy a replacement oil sender unit?? would a used one, say off a wreck or something be an option? - got better things to spend $150 on at the moment!!
cheers..
cheers..
Well, i actually ment a pressure gauge that you screw straight into the block for testing oil pressure. Most mechanics will hav one.
Its a ten min job to get the sender off. Bit of a tight squeeze with the big spanner needed, but not to bad and you do it through the engine bay. Its just nfront of the oil filters under a black rubber dust cover.
In my mind thats the easiest way of testing it, then you will know if its the guage or somthin mechanical in one simple test
Hmmm, thats high!!!
I'll dig out my workshop book from wherever its hiding tonight and double check the pressures for ya.
The regulators simple to get to, just a spring loaded valve located around the filter housing somewhere from memory. I'l check that out in the book to if i can find.
Its pretty rare to have problems of this sort in a TD42, so i would think it will be a simple fix. Fingers crossed aye!!!!!!
nuts
- Location: somewhere arround westcoast offroading usually
oil pressure
i know of a few pll having guage probs found out most of them were the gauges they r commin to pack up . im putting in a seperate guage cos mine shit
and that came from auto sparky
