Headlight combo switch issues - or relay?
For all Suzuki related topics
Apm83
Post by Apm83 »
Evening all,
Wonder if anyone can point me in the right direction, having bit of grief on the parents Vit/Escudo - highbeam does not work on headlights, but will work if you pull back to 'flash' highbeams.
I've done a little reading and found it may be either a relay or the switch itself.
Can't find the relay..... can anyone suggest where it may be.
Cheers - appreciated.
kbushnz
Re: Headlight combo switch issues - or relay?
Post by kbushnz »
My Nissan car used to play up in the headlight dept.
Would work on the flash.. but not on the normal switch.
ended up being the switch, carbon-ed up.
Didn't have relays..All the current went thru the switch...
Probably why it used to carbon up.
Calvin
kernels
Post by kernels »
Hi Apm,
I couldn't guarantee it, but would bet a biscuit that it would use the same relay for "ON" and "Flash", so I would definitely suspect the switch first. Not sure if the switch cluster is a sealed unit, but either way you can get some contact cleaner in a can, spray it inside the switch on the contacts and it will probably work fine again. I took apart and cleaned the contacts in the wife's golf's reverse light switch a few weekends ago when it died, and that wasn't meant to be serviceable either.
Good luck
Hein
Apm83
Post by Apm83 »
kernels wrote:Hi Apm,
Good luck
Hein
Me thinks you are the winner!
Suddenly started working again - dodgy contacts I'm thinking.
cheers guys
Return to “Suzuki”
