wondering if anyone knows or has put a boost gauge and tap on a d21 td27t terrano?
also what oil should i use in my gearbox , transfercase and open diffs?
any help is great thanks
were to put a boost tap and boost gauge on a d21 terrano?
another d21 terrano
ex lancer build
ex lancer build
Re: were to put a boost tap and boost gauge on a d21 terrano?
depending on what version you have, T into the boost compensator or boost sensor line.
its a 1991 if that helps. have put boost gauges into petrols but thats abit different im guessing.
another d21 terrano
ex lancer build
ex lancer build
toominator
- Bush Crasher
Castrol VMX in the manual box (4L) and transfer case (2.2L), EPX 80w90 in the diffs (2.8L rear, 1.3L front)
The boost gauge was easy, I'll get a pic tonight
toominator
- Bush Crasher
That's where I plumbed my gauge in. Not a pretty job, but I'm fairly certain those hoses aren't gonna blow off. It's max boost is 10psi
toominator wrote:That's where I plumbed my gauge in. Not a pretty job, but I'm fairly certain those hoses aren't gonna blow off. It's max boost is 10psi
That's where I put my gauge pick-up too. As I removed all the emmission gear that elbow was clear and able to be used. Now with the Intercooler on, I drilled and tapped a hole in the intake side of the intercooler and put the same elbow on. The tube stays put with over 20psi boost
I hope this helps,
Cheers.
