this gives me about 15mm clearance to fire-wall,well be wraping down pipe
Heath wrote:Almost some room for an intercooler there...
DieselBoy wrote:What manifold gaskets are people using??
I Just got off the phone to Nissan and the gasket comes in 6 separate pieces at $32each ($213+gst for all 6)
Or an after market kit for $30 total for all 6.
I thought I had read somewhere that some of the after market gaskets are arse??
Shane wrote:DieselBoy wrote:Keen for some dump pipe pic's Shane![]()
Rodger..I'll go get the D/cam
PigFmr wrote:Shane wrote:DieselBoy wrote:Keen for some dump pipe pic's Shane![]()
shane
on my 2nd turbo manifold now 1st one work well log style,now have a nice set of extractors 6 into 4 into the turbo,wiv two 2inch pipes coming out of the turbo into a collecter wiv 3inch dump pipe took a while but the dump pipe took a while to fit up to look nice,running a ct26 wiv garret internals now smaller comp wheel,also had to clock my turbo aswell to get oil feed and drain right, this mod i shud of dne 5yrs ago on the old tart gave her a new life,
vince
shane
vince
DieselBoy wrote:Got the last of the stuff required for the Turbo fitment![]()
So far the tally is![]()
DSR Turbo - Currently away getting re-balanced and Garrett bearings and seals fitted
DSR Manifold - Has had the luuurve and ready to fit
Nissan Mistral Airbox - Hacked and chopped and 3" inlet and outlet fitted, mounted complete with K & N and plumbed into snorkel
Nissan TD27T injector pump - currently in the shop along with my TD42 pump getting mixed and matched and rebuilt to Turbo spec's with boost compensator aneroid etc
I have been slack with pic's, but there ain't much exciting to see yet![]()
DieselBoy wrote:Nissan TD27T injector pump - currently in the shop along with my TD42 pump getting mixed and matched and rebuilt to Turbo spec's with boost compensator aneroid etc
nzhunter wrote:Oh dude chuuuurrr can't wait to see how it goes.......DieselBoy wrote:Nissan TD27T injector pump - currently in the shop along with my TD42 pump getting mixed and matched and rebuilt to Turbo spec's with boost compensator aneroid etc
Mint whos doing this for you??
DieselBoy wrote:Goes pretty good now![]()
Shane wrote:very nice,what boost you running at?
when crusing at 100kph what psi do you get?(no load just cruise)
hope to get mine going this weekend,I keep getting called away for work,also had 5 days in nelson.
Shane
