3B clutch and flywheel enough to handle 13BT swap?
Slideways
Post by Slideways »
Hey guys,
I've got a 3B manual in my BJ73 cruiser and I'll be getting a 13BT put in soon. Can anyone confirm if the standard clutch and flywheel from a 3B will be able to handle the extra torque of the 13bt turbo?
I do plan on running more boost and a 3" exhaust so will be making more than factory power, plus have ordered a lockright for the rear, all of which is going to put more stress on the clutch.
It has never slipped on or offroad but the 3B isn't a power house. It seems to hold on well because a while ago I pulled down a huge steel shed which had my 33' muds smoking on tarmac haha but that was 2wd without a locker/lsd.
Can anyone confirm?
H2OLOVA
Re: 3B clutch and flywheel enough to handle 13BT swap?
Post by H2OLOVA »
Different size clutch on a 13bt. 3B is 15inch and 13bt is 16.5 or something like that
Slideways
Post by Slideways »
H2OLOVA wrote:Different size clutch on a 13bt. 3B is 15inch and 13bt is 16.5 or something like that
Well I'm planning on using the 3b flywheel since the new engine was from an auto. I guess the real question is has anyone done this before? I know the bolt pattern shld be the same since I have the early 13bt redblock.
Will a standard 3b clutch be enough or will I need to source a heavy duty one.
My brother has a 3b with turbo conversion which seems to handle it but don't know what clutch it has and is only on low boost.
guestynz
Post by guestynz »
YEP ive done it and mine still going good with 3b fly wheel and clutch been in nearly 2 years cheer
IM HARD AT WORK CANT U SEE THAT
Slideways
Post by Slideways »
guestynz wrote:YEP ive done it and mine still going good with 3b fly wheel and clutch been in nearly 2 years cheer
Hey mate, how much boost are you running and have you towed or done any recoveries etc? Cheers
guestynz
Post by guestynz »
im runing full boost and towing all the time goes mint pulls like a school boy and even better on the beach
Return to “Toyota”
