http://www.nzgpsmaps.com/4wd/jan2006/1_PahaoaReccee0055.jpg
Want to incorporate a 50mm receiver for a tow ball - anyone know if I can get the receiver off the shelf or has anyone got an old towbar similar to
That I can butcher
SupraLux wrote:How long do you want the socket? I can provide you the bare socket, with strength ring welded on and pin - price depends on the length.
Failing that you can make one yourself - its 65mm square box, 5mm wall.
Steve
lilpigzuk wrote:Probably try these guys
http://www.bestbars.co.nz/home.htm
Ive got a tongue that has been welded slightly offset ie tow ball would be on a slight angle. Can have it if it will be of any use?? Got too find where I put it too
