Nissan, Model TD Series Diesel Engine, Service Manual
kbjj
Post by kbjj »
I have the titled manuel if anyone needs any info for TD23, TD25, TD27, and TD27T engine, head, lubrication and cooling system, and fuel system. Hope it might be of some help to someone.
Jeremy
toominator
Re: Nissan, Model TD Series Diesel Engine, Service Manual
Post by toominator »
just to add to this thread.. parts catalouge for most nissans. It's great for seeing how parts go together etc
http://nissan4u.com/parts/
crowbay
Stropper
Post by crowbay »
Hi, Can you give me the torque settings for the manifold and head bolts for a 1998 Terrano TD27 (EFi) please. I'm fitting a new head but can't find the settings online anywhere. Cheers
kbjj
Post by kbjj »
Inlet manifold 13-19 Nm, 9-14 ft/lb
Exhast manifold 29-34 Nm, 22-25 ft/lb
crowbay
Stropper
Post by crowbay »
kbjj wrote:Image
Excellent! do you have the valve clearances and the torque for the injectors? Thanks very much for that
kbjj
Post by kbjj »
Injector nozzle, 54-64 Nm, 40-47 ft/lb
Intake and Exhaust valve clearance, .35mm warm (with my experiance about .3mm cold)
crowbay
Stropper
Post by crowbay »
kbjj wrote:Injector nozzle, 54-64 Nm, 40-47 ft/lb
Thanks very much for your help. It is much apreciated. I have got it on just finishing things off.
