Started with a stock standard '95 V6 5 door Suzuki Escudo. Firstly some bigger tyres. 30x9.5" mudders on 15x7" ROH white spokes.
Then it developed body-too-close-too-tyre syndrome and started rubbing with articulation. So a trip to 4WD Accessories to order a 3" suspension lift from Calmini. Big thanks to Rick for getting it here for me. Then fitted it myself.
Front
Rear
Then for some water proofing. Thanks again to Rick at 4WD Acc. Fitted it myself with the aid of Ricks simple plans.
Then Comms.
Then for some front and rear protection. So knocked myself up some bars. Thanks to Uniweld Mufflers and Towbars for the bends.
Front
Upper chassis mounts
Sides
Lower chassis mounts
Rear
Bung them on with some HT bolts and crush tubes, checker plate, rubber end caps, Hi-Vis rated tow hooks and the missus' new plate.
Oh and I had the exhaust tailpipe redirected to keep it away from the rear tow hook (thanks again to Uniweld) and I also ripped all the carpets out after we flooded it in the river whilst testing the snorkel
So that's where it stands at the moment. If you've got any questions or want to know some more details on how I did something in particular just shout out and I'd be happy to help out.
