probly been asked before but try searching it and didnt fine anything, so my question is whats the standerd height of a nissan gq mesured from the bottom of a 15 inch rim to middel of wheel arch?
thanks
Standard hight
- 92 safari 17
Standard hight
Re: Standard hight
mine measures 585 mm front and 595 mm rear from center of hub to underside of wheel arch (minus flares) I *believe* factory height is around the 500-510 mm mark
--info found on the Australian patrol forum, how accurate? who knows
Mine has 2 inch lifted 500kg rated Cobra springs fitted (horrible horrible springs they are too) and on 31's (altho tyre size dosnt factor into it when your measuring center hub to guard.
