Got body lift, suspension lift and looking at putting 35's on Saf so assuming will need cert?
1) Does certifier adjust speedo so reads right with new tyres?
2) How much is it to get cert done?
3) Does cert cost include any rego or wof? (expired)
Certification cost
Re: Certification cost
Weasel wrote:Got body lift, suspension lift and looking at putting 35's on Saf so assuming will need cert?
It cost me $450 for cert
He didnt adjust anything
pass on the wof/rego as mine had both when certified
- cooksworld
$450 sounds about right. Remember to make sure that you get all the mods done that your planning as you're paying the same price whether its one thing cert'd or several. I'd also imagine that getting the speedo calibrated would be you're problem to sort (if they pick it up).
Good luck
Good luck
- skid
- Tyre Man
get in touch with your cert guy from the word go
he will let you know what has to be done etc etc
then you wont run into any hassles at the actual time of cert
Mine was 500 but that was a mobile guy. All he wanted for speedo was a mark to say where 50 was and where 100 was.
1) you'll need to get that sorted before the cert
2) down here in CHC its $380
3) No and down here you need to obtain a failed WOF (Due to no cert Plate) before taking it in.
Who knew Prados could fly?
Thanks for info
I rung our local guy the other day, enquiring to get the bush rig legal again, and he said a most definite no as soon as i mentioned body lift! strange how some interpret the law different to others aye. As long as the lift blocks are a sensible height, made of the right material, and longer HT bolts are used i don't know why there would be a problem with it. Yet i used to take it for a WOF and noone ever noticed the lift blocks, the missing swaybar, the missing flares or mudflaps, the steel pipe sticking out the passenger side where the step used to be. lol
Dont forget to update your insurance co with all the new mods
I got mine done on my safari, 2 inch body + 2 inch suspension and 35"s, was $380 but also had to get rubber extensions on the guards to pass cert also needed wider rims before going in for cert. Had to pay $30 to fail a WOF first then when the plate arrives you get a brand new WOF
Jerry wrote:Dont forget to update your insurance co with all the new mods
Very important!!! I have seen many crashes where the insurance refuse to pay out because of people failing to disclaim they have mods - even though it wasnt the mods fault that the crash happened. But thats only if they have the vehicle checked over, usually for us young drivers!
