jeep sos
fish
jeep sos
Post by fish »
i was driving up the hill out of town this evening when all of a sudden i lost heaps of power and the engine was sounding real rough, pulled over and listened for a while and i sounds as if she is only firing on 5, a there is a click or loud tap coming from the side where the inlet manifold is. also a rich petrol smell in exhaust. i managed to get it home but stalled twice and i dont know if i should run it anymore?
its a 95 xj. 4l
any advice pleeeease.
getsum
Re: jeep sos
Post by getsum »
these are push rod still right?
take the rocker cover off and check to see if a rocker has come loose..
Landynut
Re: jeep sos
Post by Landynut »
the only thing I've ever had to do with jeeps is towing them out of mud holes they stupidly tried to follow me through, or when i've spotted them stuck on the beach with an incoming tide :lol:
im with getsum though, whip the rocker cover off and tentatively crank it over, you will see rockers NOT moving, or a lack of oil (failed oil pump could cause one or more of the valves to be noisy as hell, rattling like a mad thing)
could be a million things tho, broken valve stem, cracked piston, conrod ..... its a bigass list by your description
but, the rich petrol smell would incline me to think it was a bent/broken valve letting loads of petrol through and not getting compression to fire that cylinder..
Landrover 4 Life - Best 4x4xfar
fish
Re: jeep sos
Post by fish »
yea thats the theory im going with at this stage. its in at the mechanics now. im too busy to do anything els, 8)
as for pulling jeeps out of holes ... maybe they were trying to pull you back in! :wink:
Landynut
Re: jeep sos
Post by Landynut »
hahah, yeah maybe it was you in that green jeep waving out to me stuck fast in a sink hole on the beach with water lapping around the wheels when I came driving along the high tide mark in me landy? :P
getsum
Re: jeep sos
Post by getsum »
what was the outcome??
fish
Re: jeep sos
Post by fish »
just a busted exhaust valve spring, pain in the bum to find a new one, cost me 250 to put it in, last time i use that guy.
runs great now
Landynut
Re: jeep sos
Post by Landynut »
fish wrote:just a busted exhaust valve spring, pain in the bum to find a new one, cost me 250 to put it in, last time i use that guy.
runs great now
aw sheet i just bought a valve spring compressor the other day, cost me $45 :shock: lol
easy job too if you know what your doin...
sibainmud
Re: jeep sos
Post by sibainmud »
runs great now
I have one of those for years. it's an over-head one too.
In the same kit is a converted spark plug that hooks to a compressor line with an aro fitting to hold the valve closed.
Used to do valve springs in place with Marine V8's, seemed to do more Fords than Chevs :roll: :roll:
Landynut
Re: jeep sos
Post by Landynut »
sibainmud wrote:
runs great now
yeah my chevs valves just keep rattling away, i'll leave em alone til it actually stops working eh (probly never :P)
I've used one of those spark plug air compressor hookups before, keep 80~90psi in the cylinder and the valves stay in place.... unless they leak quite alot I suppose, and you wouldnt want to trip over the compressor lead or something by accident or the valve will drop into the cylinder and you will end up taking the head off anyway to get it out haha :lol:
sibainmud
Re: jeep sos
Post by sibainmud »
Landynut wrote:
sibainmud wrote:
Landynut wrote:I have one of those for years. it's an over-head one too.
Putting the piston at TDC is a good insurance policy :wink:
fish
Re: jeep sos
Post by fish »
yea well i know for next time now :shock:
i was a bit pissed when i read on the invoice that he had changed the plugs at 12 bucks each just becuase, :shock: :shock: :shock:
ive got 6 of em too and they were ok as far as im concerned any ways like i said its all good now, got my alternator rebuilt the other week aswell so fingers crossed it should be all good for a bit
kaney
Re: jeep sos
Post by kaney »
new spark plugs are the best thing to help a jeep...well the fuel economy anyway. that and filters (all gerneral maintainence really.
the other way to hold a valve inplace is to feed some nylon rope through the spark plug hole and turn the piston towards TDC till it gets tight and the rope will hold the valve in place. (rough i know, but it works)
toymota thats stock standard.
sibainmud
Re: jeep sos
Post by sibainmud »
fish wrote:yea well i know for next time now :shock:
You'll probably find that he broke a plug or two removing them. Easy way to cover that up is to say they needed replacing :?
Good result anyway.....just the cost :roll:
Return to “Tool Shed”
