hey all
i have a 1974 fj40,i am looking for
2 factory steel rims that have the hubcap tags,all im wanting is the tags not the rim so if any 1 has any ill either buy the rims or buy the tags off you what ever is easiest
heater control valve cable
windscreen rubbers that are on top of the bonnet or the steel ones if they fit same holes
switches in working cond.ie.lights,heater,wipers etc
inspection lamp light
rear toyota,4wd badges,recflectors
christchurch/rangiora region will pick up
matt
****1974 fj40 parts wanted****
Re: ****1974 fj40 parts wanted****
PM ClassicCruiserSpares
I have a set of Split Rims will try to remember to check tonite If they have the hub cap tags.
FITZY.
FITZY.
i got all the other parts today other than the rims,
