12,000kg Pipe Bender from Supercheap
SirGerald
Post by SirGerald »
Hi
Does anyone have any experience of one of these?
http://www.supercheapauto.com.au/online ... 68#details
I see 1/2 price on sale at Supercheap $120 (norm $245)
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
Pedro
Re: 12,000kg Pipe Bender from Supercheap
Post by Pedro »
SirGerald wrote:Hi
not these particular ones, but generally the formers are the wrong size for nz pipe and crimps it, if you need bender get one with bramley formers
pedro
yes i agree with pedro got one 2'' is fine the rest the formers are to tight 1 1/4 got away with the bends, 1/2 '' was a joke
new2zukes
Post by new2zukes »
hi hope im not jacking the thread here but i have some pipe that is 48.3mm od and 41 inside what former would be suited to this one? the guys ate steel and tube said that this was 1.5inch pipe as thats aparantly what size my mates former is. so really i want to know is a 2inch former for a 2 inch nb or od.
Pedro
Post by Pedro »
new2zukes wrote:hi hope im not jacking the thread here but i have some pipe that is 48.3mm od and 41 inside what former would be suited to this one? the guys ate steel and tube said that this was 1.5inch pipe as thats aparantly what size my mates former is. so really i want to know is a 2inch former for a 2 inch nb or od.
40NB is 1.5" NB in old terms, and yes the od is 48.3mm,
50NB is 2" and 63.5 OD i think
pipe is measured ID,
Tube is measured OD
Pedro
Fakey
Post by Fakey »
I used one of those cheap pipe kinkers to build my roll cage an bars on my old 40. They eventually came out ok but it can be hard to get a consistant bend without kinking it. If youve got spare pipe an some patience theyre ok but I bought a pro tools #105 tube bender, cost heaps but well worth it IMO :mrgreen:
Didn't barbie drive a jeep??
I got that thing to use a home. work one is great but some git lost the 1/2 former :x got me out of a hole thats it
gimmemud
Post by gimmemud »
Have used one of these attempting to make some sliders. HAd two different thickness 2" pipe. the thick wall bent up no probs but the thin wall kinked the every time
SirGerald
Post by SirGerald »
cheers for the thoughts. So pretty much they seem ok if wall thick but apart from that get what you pay for.
given sale doesn't start until boxing day there is a bit of time to look around.
rokhound
Post by rokhound »
Tape off one end of the pipe you are bending, fit it with compacted wet sand, tape off the other end and then bend. It reduces the amount of kinking you get.
I have had one for ages, and they are okay, but not brilliant. I am doing my exo early next year and have grabbed my mates bender from his engineering shop to do it, if that tells you anything :wink:
Mud Hog
Post by Mud Hog »
rokhound wrote:Tape off one end of the pipe you are bending, fit it with compacted wet sand, tape off the other end and then bend. It reduces the amount of kinking you get.
Cool will try that next time :D . Very hard to get nice bends with those cheap benders.
GU patrol 35s ect.
safaripete
Post by safaripete »
if you are bending "black" pipe i would be giving it a little preheat to reduce the chances of kinking
Return to “Tool Shed”
