FJ40 Bush Truck Project
MNC
Re: FJ40 Bush Truck Project
Post by MNC »
flyingbrick wrote: :lol: but im sure i saw wayne working on the 1uz at DB's work a while back.. im the random dude that turned up half way through the morning.
Yes, that truck still looks very much like it did on that day :oops:
It is great making progress on a build but generally takes not only time but money as well...
Plan is to get this bush truck running and get out and have some fun!
PS. I remember you dude :wink:
MNC
Post by MNC »
Had some pipe left over from the arms so my bro in law made this up for the rear shocks for a laugh:
I'll make up a box to go over it and probabily incorporate a recovery gear stash into it.
I still need 1 x 30mm wheel spacer for the front - or might sell the one I have and get some bigger spacers for the front as the rear is way wider (2.15m) than the front (guessing 2m):
MNC
Post by MNC »
Oh yeah, forgot to mention the rear coil conversion has been done. This is Mark 1:
But have changed a bit due to bad Anti-squat figures. Have moved diff mounts of lower arms up to front side of Diff and chassis mounts of lower arms 30mm lower. Also dropped top arms down closer to diff head - makes top and bottom arms closer to parallel and improved the Anti-squat to about 75ish...
niblik
Post by niblik »
great stuff guy.. good to see ya tickin things off..
maybe ya bro inlaw could make you another spacer? sorry if i've already asked, but do you need them for tyre clearances..?
and stop bein such a tease... seein as its all done suspension wise, flex test plus pics!!
MNC
Post by MNC »
niblik wrote:great stuff guy.. good to see ya tickin things off..
Chur Nibs.
Bro in-law doesn't have the gear needed to make up spacers but there is another engineering place nearby that I might talk to. It may just be cheaper to buy two new ones.
Only need them to maintain full lock - I could extend the stops out a bit further to solve the problem but would prefer to have a better lock. Also rear is approx 150mm wider than front currently with the 80 series diff and 60mm of spacers on so would be nice to balance this out a bit more. Not sure what the effect of a wider rear and narrower front would have on performance :?:
I'm keen to do the flex test too - might cheat and take the shocks off first. Dont think it is going to be anything like what you and Ben have achieved though :oops:
flyingbrick
Post by flyingbrick »
question time :mrgreen:
Why do ya have 60mm spacers out back? sorry if its been covered. They just seem huge.
Take them out so you are only 30mm wider?
Fakey
Post by Fakey »
30mm each side :wink:
15" rims dont quite clear the 80 series brakes :oops:
Didn't barbie drive a jeep??
MNC
Post by MNC »
Fakey wrote:30mm each side :wink:
Yeah, bang on Fakey.
I already had the 15" rims and rubber but forgot all about 80 series imports running 16" rims to clear the calipers. The NZ trucks run 15" wheels (must have smaller calipers???) but I just completely overlooked this when buying the rear 80 series diff. :oops:
Spacers fix the problem though, and gives me more stability to go with the added height which is a good thing.
lincooln
Post by lincooln »
With a narrower front track it will increase its liklehood of rolling, thats why the mini and now most cars have wider front tracks. more stable. Just look at the reliable. :lol:
Nice work, looks good :mrgreen:
Lubrication Specialist
Lubrication Engineers
MNC
Post by MNC »
lincooln wrote:With a narrower front track it will increase its liklehood of rolling, thats why the mini and now most cars have wider front tracks. more stable. Just look at the reliable. :lol:
I would say the wider it is the more stable it is. But just by making the rear wider than stock I wouldn't see why this would increase its likelyhood of rolling over the stock setup?
I have driven gokarts with a wider rear end and they were really stable (couldn't lift a wheel no matter how hard we tried :lol: )
suzolla
Post by suzolla »
I actually think it would be better with front and back to have different track widths particularly in the mud, means that the rear will not be running in the ruts created by the front.
Tim
MNC
Post by MNC »
suzolla wrote:I actually think it would be better with front and back to have different track widths particularly in the mud, means that the rear will not be running in the ruts created by the front.
Tim
I had wondered about that - theory being the rear tires are running on fresh dirt. Maybe I run it like that for a while and see how it goes....
MNC
Post by MNC »
Time for a serious build thread update...
I'm thinking of going Gangsta like 50c so have installed hydrolics:
Oh yeah and have also changed my oil filter - not much more to go now :lol:
rokhound
Post by rokhound »
Hope you are going to use some proper tyres and not those trailer wheels :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Geezzzzuuuusss, I hope you have a good back and ankles, as getting in and out of that baby all day will soon take it's toll.
:P :P 8) 8)
MNC
Post by MNC »
rokhound wrote:Hope you are going to use some proper tyres and not those trailer wheels :mrgreen: :mrgreen: :mrgreen: :mrgreen:
:P :P 8) 8)
Yeah, its much higher than i was hoping to end up with :shock: I cant get into it wearing jeans :lol: Going to make a chain hoop under the door to assist this...
Have lost quite a bit of the guards already but might have to cut some more out for better up flex in the rear. Will post some pics to show what I mean later in weekend...
MNC
Post by MNC »
Painted the diffs and arms today. As I dont have a hoist this seamed to be the easiest way to get under there...
Managed to get 1.1m under the rear tire:
Even jacked up fully in the rear there is still plenty of room under the front guards:
Did the same to the front and got 800mm under the tire with other side still in contact with floor - just:
Everything worked well except i've got some more trimming to do to the back guards. Need to loose another 100mm or so - might also put in longer rubbers on the bump stops:
Time to prepare a list now of things to finish and tick them off one by one....
wopass
Post by wopass »
Oww thats lookin grouse!
rokhound
Post by rokhound »
8) 8) 8) 8) 8)
lilpigzuk
Tiger Balm
Post by lilpigzuk »
MNC wrote:Time for a serious build thread update...
I dont recall fiddycent being a short ginga :lol:
those tyres have a heap of surface area contact - on clay/grass does suck :? Just a concern....
side note, those nicely painted headers (in my fawkin very old zuk thread) were crap, first start up the paint was gone in 30s (much like nibby) not heat treated.
MNC
Post by MNC »
50c wishes he was a short Ginga :wink: Anyhow being short is awesome as when you take your photo standing next to a lifted truck it seams heaps bigger :lol:
Yeah, not much tread of those big tyres either so i'm not sure how they are going to go... Time will tell...
Chase sell an exhaust enamel in a spray can but they weren't sure if it would stand up to the heat of the headers - was wondering if that's what you had used?
MNC
Post by MNC »
wopass wrote:Oww thats lookin grouse!
rokhound wrote:8) 8) 8) 8) 8)
Chur x 2 :D
niblik
Post by niblik »
good shiat mnc... looks good..! (unlike rexo)
MNC
Post by MNC »
niblik wrote:good shiat mnc... looks good..! (unlike rexo)
Cheers dude - Seeing your rig out there has got me motivated to finish mine.
Have prepared 2 lists. 1st is what needs doing to make it drivable, 2nd is what I want to get done before any big trips. Hopefully get a lot of it done over Xmas break.
PS. Rexo is a good looking man - Loving those Carrot top styles :wink:
wopass
Post by wopass »
Have prepared 2 lists. 1st is make it drivable, 2nd is go up maratoto with DB and WOP over Xmas break.
fixed it for ya bro
:mrgreen:
MNC
Post by MNC »
wopass wrote:
MNC wrote:...Have prepared 2 lists. 1st is make it drivable, 2nd is go up maratoto with DB and WOP over Xmas break.
fixed it for ya bro
:mrgreen:
Keen as dude - but you know me - I work sloooooowly. :wink:
Once done i'd be stoked to go on a run with you boys.
MNC
Post by MNC »
Been ticking a few things off the first list... put radiator back in (although need to redo - water pump is leaking big time), shocks and steering (waiting on power steer hoses), and relocated battery into rear tray (wiring is a mess and needs tidying).
Anyway - its been about 12 months since the engine was last run so thought i'd turn the key and see what happened 8)
Video is off my cell phone so you need to turn volume up real loud to hear it:
Then I thought, hey its a nice day... and the truck is running now... why not drive it out of the shed and work on it in the sun...
This is this first time the truck has moved under its own power with the new suspension set up - I'm stoked :!:
Still heaps to do. For every one thing ticked off the list two more get added :? But I'm making progress :D
ClassicCruiserSpares
Awesome work dude good to see it rolling, Has it still got 2F in it? sounds like a lumpy v8 when it first started then sounds like a 2F when it drives out the door. :D
MNC
Post by MNC »
ClassicCruiserSpares wrote:Awesome work dude good to see it rolling, Has it still got 2F in it? sounds like a lumpy v8 when it first started then sounds like a 2F when it drives out the door. :D
Haha, yeah I thought the same thing - gotta love that low idle :wink:
It is still running the 2F - No plans to change that anytime soon. Just want to tidy it up a bit and drive it now.
skiddy just spent his load
awesome dude :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
niblik
Post by niblik »
oober coolies with a side order of woot!!
oh what a feeling it is to move a project under its own steam huh fella? ya get that whole feelin of wtf's gonna go wrong and excitement all rolled into one..
great stuff guy.. keep at it.. turnin those wheels in anger is next.. :wink:
