air supension compressor
red-devil
Post by red-devil »
i know i own a toyota, but
i under stand the land rover mk 3 has a compressor that run the air shocks at 200 psi when set to road.
i,ve been told they will work good as a compressor just need a tank.
well were would one find a good second hand unit.
close to chch would be grat but now that i've seen one ill ship it.
jono
tallsam66
Re: air supension compressor
Post by tallsam66 »
As its only used for suspension i doubt it would flow a very high volume of air.... would be prudent to check this out before getting one.
red-devil
Post by red-devil »
has a flow rate of about 0.96 cfm at low pressure, and according to justcompressor.com it can fill a 3 gallon tank from 0 to 150 psi in 4 minutes 45 seconds.
It is commonly used by low rider fans to pump up their vehicles. It has to keep the 10 liter (2.5 gallon)
Range Rover air tank charged up to 10 bar (150 psi),
which is a much higher pressure than most off-road air compressers can reach. The compressor also has a much harder life than the average air compressor, having to operate in hot under-the-hood conditions (it is rated at 158 degrees ambient) for hundreds of hours rather than a few minutes at a time
nstacey
Post by nstacey »
You might want to check what model you need the compressor from as there is no 'mk3' model. A series 3 definitely doesn't have air suspension but a Discovery 3 does... I don't think there is a particular Range Rover model '3' but air suspension was at least an option from around 92 in the classics. You are probably more likely to find one from a P38 which is a 94 onwards. I couldn't tell you if one would meet those specs in your post, will see if Dad has a book on them...
85 Hilux single cab
02 Grand Vitara
91Rangie
Post by 91Rangie »
nstacey wrote:You might want to check what model you need the compressor from as there is no 'mk3' model. ...
The L322 Range Rover is also know as the MK3
Theres one being parted out in Christchurch on tm here
But judging by his prices he will want a bit for it
red-devil
Post by red-devil »
been reading up a little more you'r correct it is out of a p38.
those are the specs of the pumps after a rebuild.
im just looking to see look to see if i will work, a its small enuff to fit in the rear quarter.
will be great if you can find more info
jono
Gofer
Post by Gofer »
Works like a charm, got one connected to a mobile tyre inflation tank strapped in the back of mine just fior the truck horns..............
red-devil
Post by red-devil »
were abouts did you fget one from. its a little hard to locate them here in chch
Gofer
Post by Gofer »
Try Stag 4X4 in West Auckland. They had some but not sure how their stock changes. Speak to Martin.
Disco Gofer
Post by Disco Gofer »
red-devil wrote:been reading up a little more you'r correct it is out of a p38.
jono
My recon Rangie pumpis inside behind the right rear trim panel and the tank sits out side strapped to the where the dickie seat normaly goes. From there i have plumbed the Disco right through for the truck horns, pumping tyres etc, I can give you my olf frined's name as we used to work for Land Rover and he still does a bit of mobile work and lives in Marshlands. He has a few lying around in various states of repair but can get the kits from the US quite cheap and has one in stock too when i was there 2 weeks ago.
red-devil
Post by red-devil »
Disco Gofer you've got PM
