HELP - GQ IS SHUDDERING
seven1seven
- Winch master
Hi there, have just signed in hoping to get some answers from you guys.............................
I have a 95 SWB GQ SAFARI - 4.2 Turbo, first one I've owned and am pretty happy with it, however, lately it has developed a shuddering/jerking movement.
The Shuddering/Jerking used to occur between 25-60 km/hr and has now stretched upto 90-100. With the movement getting progressively worse.
Air and fuel filters have been changed and the fuel tank treated for water (as the truck was sitting in a barn unused for a while). I thought it could be the air manifold sensor, however, the engine idles/revs fine and no "Check Engine" light is on.
Any help?????
Any help?????
Re: HELP - GQ IS SHUDDERING
yer you need to check all the rubber joints in your front suspension, we call it the death wobbles
http://www.patrol4x4.com/forum/nissan-p ... ble-24578/
What coxsy said and heaps of other possiblities.
Wheel alignment is another. It its been doing it a while it should be really obvious by the wear on the front tyres, if it is that.
know of 3 of em all were panhard bushes bout 30 bucks to replace dont do what i done and replace every other bush and swivel kit to find panhard was the problem
WARNING:
I would guess panhard also. Was the cause on my patrol.
I could feel mine in the steering wheel quite badly at a particular speed.
Otherwise wheel alignment or rod ends would be my next stop. Then maybe wheel bearings.
Also, check your rear drive-shaft for play, a dodgy UJ gives a nasty shudder too......
seven1seven wrote:Hi there, have just signed in hoping to get some answers from you guys.............................
Any help?????
is it shaking through the steering wheel? or more like a engine missfire?
also is it std hight or lifted?
seven1seven
- Winch master
Hi, its as if the engine is missing, however at the 90-100 km speed the wheel starts to shake, which I put down to tyre balance.
seven1seven
- Winch master
Suspension is standard.
the 3 litre patrol i hired is aussie, had same condition, and gave the britz hire comany a ear full about it, standard or modded still check the bits we pointed out
seven1seven
- Winch master
Replaced the bushes today on the lower control arms (as there was quite a bit of play on the left one) + a wheel balance and alignment. A bit better but problem still there.
- firestonecruiser
panard rod bushes or cud you possibly have a delaminated tyre.
seven1seven
- Winch master
Panhard rod bushes next pay.................
Where are you?
seven1seven
- Winch master
Auckland
seven1seven
- Winch master
AUCKLAND
HAVE YOPU CHECKED YOUR KING PIN BEARINGS FOR PLAY. It will be your swivel hubs.
Al
Al
seven1seven
- Winch master
Maybe a better way of describing it is: It feels as if you are bunny hopping. As it is a fore/aft motion.
seven1seven wrote:Hi, its as if the engine is missing, however at the 90-100 km speed the wheel starts to shake, which I put down to tyre balance.
So if it is the enine missing stop doing suspension fixes!
It can only be so many things if it is engine related. Is yours auto or manual? Does it do it related to engine revs only or load and revs or speed only?
Does it do the miss when stationary?
Does the engine speed effect it or just road speed?
It could be water in the fuel. It could be an air leak. It could be a dodgy driveshaft.
Whole different ball game
Coast down a big hill at 100Km in nutural with engine at idle. see if it goes away?
Tony.
I had dirty diesel when mine did a similar thing.
I wondered if it was engine related but thought from the first posts surely not
the shudder at 100kph though will more than likely be panhard bushes or King pin bearings
good luck with finding the issue .. It took me 4 months and lots of $$$$ to finally get rid of all the wobbles/clunks/knocks/bangs/vibrations and shuddering out of mine
drives like a new truck now though
He lives in Auckland. Somebody really needs to make contact with him to have a drive and get a better description of the fault. I am picking there could be more than one issue here.
he just left here, i drove the truck in a big circuit down to the airport rd then down to the motorway then back home, their is some i my opinion a slight shudder in it at 50 to 60 kmh in third,but its a 1995 turbo manual {nice driver] there a small vaccum hose which comes off the oil pressure sender which is not attached to anywhere and a sensor on the rear intake with wires cut broken?
seven1seven
- Winch master
Thanks to all you that offered ideas. Problem of shuddering / surging is sorted.
Left rear wheel bearing, castle nut had come adrift. Pulled the axle out, cleaned it up, old bearing back on, done up, tab washer up, sweet as a nut. Happy as f*#k.
