Engine rumble
Engine rumble
Guys suspect this is common as have heard it on other TD42's. Its an irregular rumble/rattle and sounds like its coimng from the waterpump or front of the engine somewhere? Like something hitting an aluminium cover somewhere. Want to sort it as it does not sound great but not sure whats causing it. Almost sounds like a timing chain rattle?? Do these things have tensioners that wear and are they easy enough to replace? Anyway, ideas or experience on this would be helpful. Thanks.
Re: Engine rumble
Other than your standard diesel rattle....
timing is geared.
Mine was the water pump. Had lots of shaft play and rumbled real bad. Couldn't tell from inside but mates outside said it was real bad when driving away.
Running two stroke oil in the fuel quietened the engine/injectorpump down a bit too.
timing is geared.
Re: Engine rumble
Yeah i can't really hear it in the truck but round the front it sounds bad like an irregular rumble. I thought it sounded like water pump. So was the play in yours shaft in and out movement. Can you feel it by just dropping the belt off?
Re: Engine rumble
I could see mine with the belt on
Was side to side on mine. You should be able to feel it quite easily if its there.
Re: Engine rumble
i had something like it, but mine was the air con pump. take one belt at a time off and see if the noise goes away. good luck
Re: Engine rumble
This one you got to be real careful.
Use a big screw driver like a stethoscope or buy a proper one from super cheap or somewhere like that.
Put one end to your ear and prob around with engine running.
Have never had a noise I can't find with this method in engines or drive trains
have heard a noise like that once before. Turned out to be the alternator. One of the long bolts that hold them together was broken and the head was hitting the cooling fan.
Re: Engine rumble
my engine has a wicked bad rumble to it...
but its a chevy plant so i put up with it
- Crash bandicoot
Re: Engine rumble
wopass wrote:my engine has a wicked bad rumble to it...
but its a chevy plant so i out up with it
Cubic inches dont count
Re: Engine rumble
Crash bandicoot wrote:wopass wrote:my engine has a wicked bad rumble to it...
still has a wiked rumble
Re: Engine rumble
Swamped wrote:.
oh fark yeah ... cant believe how much it quietens it down
- safaripete
Re: Engine rumble
meece4x4 wrote:Swamped wrote:.
pisstake?????
as i used to premix it in my rx7 but never heard of this
Re: Engine rumble
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=46&t=17960&hilit=2+stroke+oil
http://www.audi-sport.net/vb/diesel-forum/48309-2-stroke-oil-diesel.html
A few people do it/ have done it. Does help....in my truck at least.
Re: Engine rumble
No pisstake at all...I've been putting in 2T for over a year and as said, way quieter engine and happy inj pump.
38 pages here.
http://www.patrol4x4.com/forum/general- ... uel-37562/
38 pages here.
Re: Engine rumble
Definately helped quieten down my old TD42, will consider running it in the new one when I get it too
Re: Engine rumble
safaripete wrote:meece4x4 wrote:Swamped wrote:.
pisstake?????
no pisstake
works,
I run 1:200 mix every second tankful to keep the pump lubed, works as well as the diesel additives, and really makes a noticeable difference to the clatter, so much so on my truck the wife knows instantly which tank it's on.
some people say it improves economy and power, cant say if it made any difference, there other than the truck "seems" smoother to drive when its got oil in it. Im doing it to safeguard as much as possible the pump since we are forced to use that shitty stuff they try and palm off to us as diesel.
