recovery gear
Drop shackles....
ramon
Post by ramon »
Supercheap dont sell "recovery hooks", i think they call them tow hooks to cover their arses should one break and kill someone.
turoa
Pyro Junior
Post by turoa »
Jerry wrote:Drop shackles....
No... Youll never guess.
Plywood suspension?
niblik
Post by niblik »
TRACKS :!: :wink:
turoa
Pyro Junior
Post by turoa »
Jerry wrote:Plywood suspension?
No jerry, although that is a good idea.
Nib, I wish. Dome landrover do have tracks as standard equipment though. And you used to be able to buy conversion kits that bolt on where your wheel usulally goes
Its not a lowered suspension with neon lights underneath it + a 2 foot wide exaust?
A heater?
I must point out it makes the perfect BBQ table !!!!!
pirate
Stropper
Post by pirate »
Well guys thanks for all the replies, I sure have got some good info now, and i will make the most of this. Sounds to me like it's a good idea to stay away from supercheap and take a trip to repco , or order online. :)
pirate
Stropper
Post by pirate »
Thanx for the tip h2oluva i think i'm heading to steel and tube. :D
Dethklok
Re: recovery gear
Post by Dethklok »
Hi all,
I've gone and brought some 10000lb rated hooks... does anyone know what bolts I need to fit them to the front mounding points on a '91 surf? (the captive nuts). I think I found it on here once before, but I seem to have misplaced it. :(
Went to the local wreckers... no help at all.
mbw
Re: recovery gear
Post by mbw »
Take it to your local Blacks fasteners or similar shop and ask them to have a look at what you need. I'm sure they'll help.
Dethklok
Re: recovery gear
Post by Dethklok »
If anyone else ever has the same problem they were M12x1.25x50.
