this show a spacer and a bush for manual hubs , swamped was on the right track
Hombrey wrote:Guys I've got problems with mine but I went from an aftermarket set of manual hubs which i broke to a set of original replica Nissan manuals. Prob was the nissan ones did not come with the spacer but they do need it as they slip under load. Not sure on the change from auto to manual ones though. I measured it up and found that when locked in at worst case (the inner clutch part slid fully in on the splined hub) the teeth only just mesh, and with a little grease and under load they slip. A spacer behind that inner clutch part between the hub face and the clutch of I reckon about 4mm max would be enough to ensure they are are positioned out far enough all the time so when you lock the outer in the teeth mesh enough to eliminate slippage but still disengage properly.
