Hi , Ive just brought a 90' Escudo. It has a G16A 16v engine in it at the moment with a blown cylinder head. I have also just brought another engine but its the 8 valve G16A(both are injected). Aside of the valves, is there any major difference between the two? Would I be better off swaping the heads over or just transplant the whole engine over?
Thanks for any help ,Paul
8 and 16 valve suzuki engines
Yeah you should be able to swap the heads as the engine blocks are the same, check out the forums at http://www.teamswift.net it has heaps of stuff on these engines and you should be able to find some answers there.
- Escudo-boy
- Newbie
yer,went there for a visit.It was mostly 1300 stuff.
But It turns out this 8 valve engine Ive brought is carb'd. Should it make any difference? Will the injected manifolds still fit? I think Im just guna strip the 8 valve block/head and stick every thing form the 16 valve on it.
Does anyone dissagree?
Cheers Paul
Cheers Paul
