How to remove windscreen on navara??
For all Nissan related topics
Damz
Post by Damz »
Its glued in, I think? Had no experience working with glass, any help appreciated :mrgreen:
Crash bandicoot
Re: How to remove windscreen on navara??
Post by Crash bandicoot »
go to super cheap and get the proper tool, its an L shaped blade on a handle with a cord to help pull it through the urethane
bout 19 odd dollars from memory
dont try and get a screw driver under it unless it is already cracked,
if you can get a hole through the glue inside to out get a couple of pieces of wood dowel and some copper wire and make up a garrot type tool and get a mate on the inside to help pull it back and forward around the windscreen.
Damz
Post by Damz »
Any idea what the tool is called mate? Might go for a wander this avo
Crash bandicoot
Damz wrote:Any idea what the tool is called mate? Might go for a wander this avo
http://www.northerntool.com/shop/tools/ ... _200334173
exactly that windshield removal tool.
rokhound
Post by rokhound »
These tools work really well if they have decent blades, and the one I got from SC didn't :(
But if you can get someone to help you, then the garrot idea works very well. I used piano wire as it has a texture and cuts that wee bit better. Failing that, get BFH and then kick the shit out of it, (makes a bloody mess though :lol: )
Damz
Post by Damz »
Thanks for that guys, will be going for the latter idea. Thanks again!
Return to “Nissan”
