NJV6 wrote:I reckon it sounds like the solinoids are working fine...
Run a jumper cable from the single post the the end of the motor (A) to F1 and another jumper from F2 to +ve on the battery and see if the motor works.
And the rope - with a kink like that just wind it on tight and it'll pull back to its normal shape.
Maybe I should have read this a bit better before I started...
I pulled the solenoid apart and everything seemed ok inside, no water or dirt ingress and both switches inside work.
I tried the winch with 3 jumper cables, one to the earth, then +ve to the other two, one to the red or yellow terminal the other to the blue. But got nothing, NJV6, is what your saying is it should be say connect the blue to the red terminal then yellow to the battery? It was completely dead with what I was trying didn't even get a spark.
I pulled it out and apart, if nothing else I got to see inside it...
My Dad reckons its down to just corrosion on the terminals on the outside of the winch, they've been cleaned up a bit in these pics. I'm not convinced. Anyone see any other issues with it? Also, is there an easy way to get those brushes back in when reassembling?
