Rear Recovery point
Disco Gofer
Rear Recovery point
Post by Disco Gofer »
My 93 Disco has a tow bar with a removable hook and want to know if its accepted to buy/ make an attatchment to slip into the same square tube with the rated cast hook on it? I got a couple of hooks from Supa cheap and want to pop them on before my first club trip next week end.
Being a Landy i mostly only need the hook at the rear to pull other out........................................BUT need to mount one on the front for looks too. Haha
Furgus
Re: Rear Recovery point
Post by Furgus »
I'm sure what you're planning will work fine, I went down a slightly different route & bolted my hook to the chassis.
Disco Gofer
Ah yes cheers!
Lynx
Post by Lynx »
Disco Gofer wrote:My 93 Disco has a tow bar with a removable hook and want to know if its accepted to buy/ make an attatchment to slip into the same square tube with the rated cast hook on it? I got a couple of hooks from Supa cheap and want to pop them on before my first club trip next week end.
Will see how long that statement lasts hahaha.
Mount it through the chassis like above, less time pissing around.
Cheers Daniel
Stage1V8
Post by Stage1V8 »
Just remember that if you do, put crush tubes into the chassis rail before tightening the bolts.
Alan
Land Rover Series III Stage 1 V8
Disco 2 HSE
