well bit of an update.. things are slower now..
Working on electrics and we are going to extend the loom into behind the seats....
these ecu's are moving to that area,
Main ECU, approx 65 wires
Fuel pump ECU, approx 8 wires
Fan ECU, approx 6 wires..
All will be apporx 1.5-2m longer.
Ignitors will stay close to engine.
Since starting up we have been pondering the options etc and have come up with that.
Started to get exhaust and pto winch sorted out.. looks like the pto will pop through a hole on the passenger side front chassis member straight into the winch drive..
, Have to mock up the drive shafts offset a little to allow for the exhaust to run.. and that will be interesting exercise too
the exhaust will need a complete remake as the chassis it came out of is totally different to whats now..
Ran clutch master and slave to gbox and it has worked out ok too..
Have placed my doors on the truck and they need lipstick..otherwise they are looking great. Same for bonet..
I'm thinking of probably needing a 2-3" lift or even more once the winch gets installed as there is only approx 20mm atm till the bump stops hit
, she is deff front heavy..LOL
Probably going to go with 33" tahs so I can play inter club games..
and get some 35's for later on..
Once the ecu's are placed I'll post up some pics..
cheers K
