Terrano shaky steering, bumpy ride
Ok so i was stuck for 4hours ish down the waimak today, took a 12,500lb winch with another stuck snatching me to get me out, that was allgood, but when i was driving home at 50kph the steering wheel shakes badly and then 70+ the steering wheel stops shaking and the whole truck judders up and down. I know terranos have weak front ends so im thinking its something to do with that? I havnt had a proper look yet, but what should i check first?
- Crash bandicoot
Re: Terrano shaky steering, bumpy ride
clean the mud off your drive line and inside of rims.
then go for a drive.
then if its still shaking a wheel alignment might be in order as the force of the winching has pushed the suspension geometry out.
if its a 1995ish model also change the bolts on the bottom of the front struts. before going for an alignment.
M16's from memory
M16's from memory
- mud_slinger
get the mud off and balance ya wheels
needs more curry
0272593533
0272593533
all sorted cheers. Was just the mud on inside of rim..
