Remote transfer box
brakes-shocks-lockers-etc
madtoolbox
Remote transfer box
Post by madtoolbox »
Im putting together a escudo/hilux/commodore V6. I have a remote transfer box from a patrol. Anyone have any reasons why i shouldnt use it behind the V6 auto? Be nice to get some feedback before i mount it up.
Also, where is a good supplier of rose end joints for making my diff links.
Smurf
Re: Remote transfer box
Post by Smurf »
You'll end up with a super short rear driveshaft with a remote transfer in a Scud. May be ok in a LWB though?
callum007
Post by callum007 »
If its all going to be hybrid, just use a bighorn auto and transfer case on the commy6. like smurf said. short rear tailshaft, i looked into this for mine too.
De-Ranged
Post by De-Ranged »
callum007 wrote:If its all going to be hybrid, just use a bighorn auto and transfer case on the commy6. like smurf said. short rear tailshaft, i looked into this for mine too.
Does the bighorn trans bolt onto the commy ? or are you talking about the bighorn transfercase onto the commy trans.... don't think the later would be a good option in a scud, the front drive shaft is going have clearance options to the trans sump
Cheers Reece
callum007
Post by callum007 »
well, i cant say from experience but I was under the impression the bighorn auto fitted the commy, but now i've re read my info on it i think i meant just the transfer case.
i have no idea on clearance.
tgaguy1
Post by tgaguy1 »
What side is the front drive shaft output on the Isuzu transfer case?
I thought it was the LH side.
madtoolbox
thinking i will use the lux chassis and shorten it up as much as i can when running gear in in place, will fit the scud body after that.
meatc
Post by meatc »
I know a guy who has used that motor / box combination and has had all sorts of issues getting rid of horrible driveline vibe caused by having to push the transfer off centgre slightly so the front shaft cleared the auto trans pan. Think he has it straight now but may have lost a bit of front flex to stop front drive shaft hitting auto. Did it ona standard lenght GQ chassis and has basically 2 ujs as a jack shaft and a pretty short rear shaft. Motor is back a bot though to increase approach angle.
madtoolbox
can anyone confirm if the isuzu transfer bolts onto the holden auto?
De-Ranged
Post by De-Ranged »
madtoolbox wrote:can anyone confirm if the isuzu transfer bolts onto the holden auto?
Bolt on "No" it needs a custom addapter made for it to work.... the reason its used is becouse the output spline of the trans is the same as the input spline on the bighorn transfer case so no expensive machining of splines....
I have one in my shed at the moment I built up, the clearance issues can be beaten if you build a custom D/S thats very narrow to clear the trans sump and clock the trans to help clearance
Cheers Reece
