WTD.. 80 series 3-4" front springs
Big
Post by Big »
Howdy peeps,
I'm on the lookout for some lifted springs for my 80.. I'm thinking of around the 3-4" :mrgreen: lift but if you have more I'd seriously look at them as my shocks will take a 6" lift :shock:
If you have some can you let me know..
cheers K
mudlva
Re: WTD.. 80 series 3-4" front springs
Post by mudlva »
hi there do you have a set of standards and where abouts are you?
Big
Post by Big »
I'll have the front standards and not sure about the rears yet as it's sitting high in the rear atm..
In Queenstown too 8)
I'm just trying to balance it out as it's sitting low front wise.. only got about 20mm till bump stops start compressing.. :roll: .
Thats with the winch now on and I have a 45mm bump stop spacer too..
wjw
Post by wjw »
I've got a set of 3" coil spacers for an 80? Bought a 6" lift of TM, am using the springs but shocks and spacers are spare...
Who knew Prados could fly?
Big
Post by Big »
wjw wrote:I've got a set of 3" coil spacers for an 80? Bought a 6" lift of TM, am using the springs but shocks and spacers are spare...
That would be good IF Pete would allow it.. He's saying they need to be held or captive so the it's like the original spring mount.. If I could do that then it would be a goer.. I think it would be better to have longer spirngs anyways.. I'll keep looking thanks anyways.. Cheers K
wjw
Post by wjw »
ok no worries. Might be worth a call to 4wd upgrade in Christchurch, the 6" kit I got was from a cruiser they were wrecking. $200 for shocks, springs, spacers and steering damper
cool__bananas
Post by cool__bananas »
a 4" is mega high, i just got it but i kinda wana make it lower, its huuuuge haha
Fakey
Post by Fakey »
Your going to all the trouble rebuilding the truck, why not get it all set up with bar work etc then lower the spring perches on the chassis to suit :?:
Didn't barbie drive a jeep??
Big
Post by Big »
Fakey wrote:Your going to all the trouble rebuilding the truck, why not get it all set up with bar work etc then lower the spring perches on the chassis to suit :?:
That is an option.. I'm just really not wanting the extra work in doing that as well.. but depending on the funding.. it might just happen.. :shock:
Fakey
Post by Fakey »
I know what ya mean Id need a set of 100mm lift patrol springs ($400 for the pair new) just to get the front up to the same height as it sits with std 80 springs. Trouble is the 80 springs dont fit in my patrol spring mounts ive already welded on so ill be cutting them off an making new ones for the 80 springs intead of spending an extra $400 :oops: :lol:
Return to “Toyota”
