Boogers build thread
Nivapulledout
Post by Nivapulledout »
booger before any mods apart from 30" half worn BFGs
Right so I have finally gotten around to resizing all my build pics and so will start my build thread on ORE.
My little green ball of snot(booger) had done me proud as a cheep commuter wagon and great for camping in remote places with the mrs however Two years ago I got a winch and needed to fab a bumper to mount it to. unfortunately the bug caught and now have modified alot of things. it has been one and a half years so far( I do live overseas so only really 8 weeks of actual work) to get this far. I have only added a few comments so sorry about the brief description, I am sure most of you will get the idea though. and if anyone wants more of a description about something just ask :D
Seats were on the list and I happend to have some BMW E36 coupe seats spare. no more wobbly uncomfortable seats.
fully height adjustable. wicked.
make a round bumper hole square.
give it some extra bracing.
all painted up waiting for winch fitting.
out with the old engine
plan
a week part on the Nivas is the alloy front diff which is also mounted to the engine so gets twisted with the engine. To solve both problems I plan to turn a spare rear steel axle into a steel front diff that is mounted to the front crossmember.
making a jig off the original.
first line up
alot of grinding needs to be doin to the pumpkin as the output flange and bearing sit so close on the short side.
the step is for the bearing to sit in, it is a real close call.
all welded up looks good.
mounts made
fitted to the front crossmember
the air lockers (from greece) and 4.7 gears(from germany) fitted ready for installation :D :D It is really hard to find aftermarket parts for ladas. I also have a Russian torsen/quaif type LSD as a spare.
wedges for the front spring base, this is what we lada guys call a Hoodoo Mk I after the guy(Hoodoo) that first did this mod.( he has joined ORE now) the MK II just uses spacer rings on the springs but although easier to fit tent to make the spring bend more. the wedges straighten the spring up .
all painted
new progressive front springs from Russia
needed some extra weight to compress the springs he he
cant be calling these progressive any more huh :lol: :lol:
got progressive springs for the rear as well as adding a spacer. the hoodoo lift gives approximatly 2" of lift. :D
the old rear top spring seat and the new lifted one.(From Russia)
now I dont like the rear drums on the Niva as the forever need adjusting. so decided to retrofit disks.
rear axle flange machined to take a Niva front disk.
I used citreon ZX calipers just cause I was at the citreon wrecker for some engine parts, he also gave me the mounts. so I welded them on.
Looks Great does it not!!! :D
Image Custom handbrake cable fitted nice, wasnt cheap though!!!
Nivapulledout
Re: Boogers build thread
Trial fitting the Peugeot 1.9 TD
because the diff sits right under the sump I have to graft the lada sump onto the pug sump. bit of a bugger
hard to weld them sumps. all the oil impregnation so get lots of pinholes. also need to screw to a board to stop warpage.
oil pump pickup now fouls the new sump. going to be a tight fit.
cut off the pickup
Press in some copper fittings
a couple of 90s and some heavy brassing to make sure it does not crack or break off.
the difference between the lada flywheel position and the pug is obvious a flywheel spacer will be needed.
the spacer allowed me to house the lada spigot bearing as well which solved that problem.
made up my own adapter plate with a bit of dead reckoning.
Cut the Lada gearbox to accept the pug starter mount I had cut off.
Ready for welding, I kept the starter pattern on the adaptor plate so that I could use it for alighnment . some more calculations to get the distance correct. cut spacers that length and bolt it all up.
welded with a minispool gun on my mig. not so tidy but great penetration. I then cut the starter pattern out of the adaptor plate.
the Pug flywheel was slightly bigger than the lada one so needed a bit of a grind inside the bell housing to get it all to fit.
because the starter now sits back further the block needed a bit of a grind as well to allow it to fit.
the lada friction disk fitted the pug Non turbo clutch plate so I grabbed a non turbo flywheel from a wrecker and a new pug pressure plate.
edit: once I got it all together and engine running I could not get the clutch to disengage!!!!! I think this could be because of the two different components, I have now found out from someone else in the uk that I had copied the idea off that he actually used a complete lada clutch assm as it bolts on ok to the pug flywheel. I am yet to confirm this but when I get home will need to rip out the engine and try and see if a complet lada clutch fixes the problem.
Edit: it is now confirmed, if doing this mod Use the complete lada clutch. as it was the pug pressure plate not compatible with the lada friction disk thickness.
Last edited by Nivapulledout on Fri Jan 25, 2013 9:16 pm, edited 3 times in total.
Nivapulledout
the first offering up.
kept the lada splash guard with a bit of modification
Starter bolted up nice and engaged when a bit of juice was applied. must have got those measurements correct.
made a new mount for the mitsi 90amp alternator, keep it high up and out of the mud, needed the mitsi as it has a vacuum pump on the back. the pug vacuum pump bolted on the back of the cam but this fowled the firewall.
the diesel needs a return line to tank so grabbed the fuel line off my wreck and ran that next to the suction line. easy no bending required.
all plumbed in
in she goes, Ugly bastard that :D
modified the mounts
LH side
Nivapulledout
RH side
its in with no Chains holding it up yay
had to modify the intake maniolds as the stock one did not suit
manifolds on and plumbing connected.
Nivapulledout
modified this so the vacuum pump can drain into it.
should not be overheating with these puppies :)
the start up vid, started first time after a crank with no fuel to get oil pressure. happy chappy.
http://www.youtube.com/watch?v=I7YRBmRyhFs
I am now back overseas so wont be any progression for a while unfortunatly.
I still need to pull the engine and gearbox again as the clutch is not engaging for some reason!! hope I have not stuffed something up.
Mods still to come.
box section sills
virtual lift
fab rear bumper and tow mount
fit rock crawler gearbox 3:1 ratio
roll cage
on board air using sanden pump.
Snorkle
certification.
mercutio
Post by mercutio »
wow awesome stuff dude :D :D :D
i used to own a lada way back when mine were just cars though man i used to thrash them lol
my 4wd is not a truck
haynzy
Post by haynzy »
pfffft its just a lada :roll: but awesome thread dude gonna be a good build when finished fab work and innovation is awesome 8)
Nivapulledout
Cheers guys, I cant wait to get it back up and running and give it ago. I have woodhill in mind for the test. or maybe thompsons or the wires.
SP450andLE
Post by SP450andLE »
Nivapulledout wrote:Cheers guys, I cant wait to get it back up and running and give it ago. I have woodhill in mind for the test. or maybe thompsons or the wires.
Ooh, I could organise some sorta get-together at my Dad's farm, in Kaiwaka. (It has mud, bogs, hills, creeks...)
Also, you have done pretty much everything I want for the Fiva. Oh well, if all goes to plan, i will be making awesome ad's for all to see, and getting piles of money :lol: :roll:
I'm glad you chose to share this build with us :D
rokhound
Post by rokhound »
That's all good shit dude.
Nice to actually have some tech threads where guys aren't scared to give it a bash. Also some good inovative ideas and problem solving. :P :wink: 8)
Nivapulledout
cheers Rokhound, there was many a time I would be sitting there head in hands going"how the hell am I going to get around this" but you always find a way. normally just means more work/money than you planned.
I am Enjoying doing up the Niva cause it is something different to what people have. I like the jokes and banter. and I think it looks cool. Plus the value factor of beating people in a lada and seeing their faces he he.
SP450andLE your dads farm sounds like a blast. might have to take you up on that offer. keep working at the Fiva and you will get there mate. at least you have time to work on it.
SP450andLE
Nivapulledout wrote:Plus the value factor of beating people in a lada and seeing their faces he he.
Oh so true :lol: :lol:
And yeah, the Fiva will be ready soon. I just fixed the hole in the radiator tank, where the drain plug broke off.
Even if it's not road legal, it should be going good on the farm soon. :D :mrgreen:
DMcCready
Post by DMcCready »
What rokhound said... awsome to see a different build that has taken a huge amount of thought and engineering.
Keep at it mate, going to be one unique vehicle!
There's gotta be some rocks round here SOMEWHERE!
rotordogg
Post by rotordogg »
Nivapulledout wrote:cheers Rokhound, there was many a time I would be sitting there head in hands going "how the hell am I going to get around this" but you always find a way. normally just means more work/money than you planned.
I find having another beer and staring at it for awhile help's too!! :lol: :lol:
I'm kinda frustrated not being able to work on mine at the moment too, but sometimes other things take priority. :(
Will be good to have Booger up and running, We'll definatly have to organise a lada get together when your all ready for it!!
I'll bring miniskip up for that!! :D :D
It's just more fun in a lada !!
Bolo
2XL
Post by Bolo »
looking good mate , keep up the great work
niblik
Post by niblik »
every since i knew this hairy samoan dude that was into his cuddles, who had one, i've liked the ladas.. my only peeve was the fact the motors were prone to be throwin a hissy when splashed with water.. it'd look at the dew on a mild morning and it'd pull up its petty coat and sob like a rumless rex.. always thought the diesel mod would rock..
you've found some interesting issues when performin your mods and have found truly ingenious ways to counter them. neat to see some lateral thinkin and can do attitude..
well done sir..
neat little right up.. will be lookin forward to seein more vids and updates from ya..
8)
sibainmud
Post by sibainmud »
I gotta be in on this :mrgreen:
Always wanted to line up beside the Fiva :lol: :lol:
I trust the invitation is in the post :?: :!: :?:
Awesome build.
SP450andLE
sibainmud wrote:I gotta be in on this :mrgreen:
Line up beside it? It'll leave you way behind once it is going properly :lol: :lol:
Nivapulledout
Hay all
Well Me and the Wife have finally returned home to NZ for good!!! and with a south Island trip planned for all of Feb I need to (and have permission to) go full steam and get the Niva finished so we can take that.
after getting Christmas and New years out of the way I have finally got stuck in over the last two days. here is the progress and I am dam happy to have got back into it.
So I retrieve the lada from storage and drag it over to dads place, took a while to get the head back to where I left it with what needed what doing.
Biggest thing was pulling the engine and finding out why the clutch was not disengaging, I had done more research and it seemed that possibly the lada Pressure plate will fit onto the Peugeot Flywheel. So pull the engine/gearbox I did and low and behold even though it looks bigger and alot gruntier it bolted straight on. ( If only I had tried it originally but I just assumed that it would not Bugger!!!) As you can see there is quite a difference in the appearance and I am guessing the lada Friction plate was too thick for the Pug Pressure plate to cope with.
The lada Clutch looks alot bigger but bolt pattern is the same
the release forks are also alot further out.
Dad my forgetful (Has Alzeimers) Helper... he loves working in the shed with me though.
So I chucked back in my old Lada clutch as it was looking like new still and bolted her all back together. threw it all back in and bobs your uncle after a quick bleed it works perfectly, proper freeplay and disengagement woop woop.
Now I can carry on getting everything all connected for the final time and do alot of tidying up of the wiring. I also Ran the breathers for the diffs,Tcase and Gbox up to the engine bay. I Also ran the airlines for the difflocks.
And then with a little bit of time to spare I quickly knocked up a Steering box brace as Nivas tend to rip out their mounts from the thin panel. this way it sandwiches the body panel between the steering box and the plate.
I am hoping to get it illegally drivable just to get it down to the exhaust shop on sat before we head off up north for 5 days so it should be ready for pick up when we are back!!!
ladeda
Post by ladeda »
awsome. welcome home its about time. :D
De-Ranged
Post by De-Ranged »
From what I've seen the steering issue isn't the body its the alloy mounts splitting on the relay bar mount or the steering box its self dieing....
Cheers Reece
SMOKEY
Post by SMOKEY »
Welcome home Craig -------- NZ for good :? , coming from you that's a bold statement, not starting nesting are you :?: . I'm still enjoying this write up and looking forward to seeing Boogers and you's during your south island Trip.
place TUI add :shock: ,
NIBBZ IN A LADA,
FITZY.
rotordogg
Post by rotordogg »
Great to see progress on Booger again!! Make sure you drop in here on your way south. :D
My steering ripped the crush tubes out of the 'frame', I added a plate on miniskip on the outside, and it has adaptor plate for power steering on inside of frame, made it nice and solid. (was a pain in the arse to get into work on with mine being diesel too!!)
Dogg.
Nigel Bannan
Post by Nigel Bannan »
Hi There. When you get to the south there are plently of good bartasd's to put you right. Give us a bell. Nig
Nivapulledout
Cheers for the comments fellas
Yes am Back for good and seems like I am nesting as well. we just got back from Whangarei where we were sizing up builders to build on our section up there. Wont be till early 2014 though.
Will start a South Island tour thread and try and touch base with anyone that I have talked to or is keen on meeting up... so watch out for it. Always keen on meeting good bastards that are keen to give the lada a bit of shit.. Ha ha
Reece yeah I know the box is week but mine is in good nick at the moment and have 2 spare ones ready for when it hang grenades, Was planning on putting Cloggys Toyota Cresida power steer box in (have it in the shed) but could not fit it in with the turbo. Soooo I will just have to be nice to mine ha ha. Will be coming to the bay for a bit as well so will have to try and pop around this time.
Dog will be sure to pop in after all the help you gave me on Booger a couple of years back.
Nivapulledout
Had taken Booger for a little spin before dropping him off to the exhaust shop and boy he sounded good (just the dump pipe on and lots of waste gate fluffing on lift off :evil: :evil: :evil: :evil: :evil: )
Back brakes seemed to bed in as well and the handbrake improved alot ( I hope enough, I think it is struggling with the 31" tyres) Drove nice even though need to sort out the Camber and alignment.
Still heaps to do but got the call from the Exhaust shop as we were driving down today and it is all done.
Talking to Neil Miller the Cert Guy I am using in Hamilton and it seems the regs on the ball joint spacer for the upper wishbone to Hub joint has tightened up and it may push it into a Higher inspection/testing Zone (bugger) am popping into him to give him a heads up on it while on the way home tomorrow. He is also swamped with work and possibly the South Island trip is going to be delayed if he cant do it next week. :(
Nivapulledout
been a busy few days since the last post, trying to get time to work on the lada is a mission, My idea of free rein to get the lada finished is not quite what the wife had in mind ha ha
Decided to keep it short and use the pics to describe, if anyone wants more explanation or more pics just ask.
Cheapest and easiest intake pipe as under no pressure. the dreaded PVC ha ha but it took me 2 min with a gas tourch and a block of wood to mold it like this so it clears the rocker cover.
Temp mock up of where the intake and boost/intercooler pipes will be.
intercooler still needs mounts, going to be a mission to get it sitting at the correct height to seal against the bonnet.
the Wiring is deloomed and a mess.
Went to fill the cooling system (lucky just with water) and found that the plastic fan clamp thingies that were supplied with the fan had holed the radiator in 3 places. they push through so must have nicked the fins. took it down to the rad shop and they said those mounts are shit and to make better ones as even if they fix the holes with the vibrations the plastic will wear against the fins again. so some right angle and a few bits of threaded rod and the Mk II version was born,(should have done it this way in the first place lazy bugger)
Looks good
Nivapulledout
rear
Front
Diff breathers (and gearbox and Tcase) just had a little mushroom one one valve thingy, Flicked it off and just did as per pic, No time to muck around trying to find the correct sized hose tails, Different threads in each breather go figure.
Front diff lock line and front diff breather hose runs
mounted new secondhand mitsi (alternator this time a 12v one) with a new belt. wired it up and tested 14.2 v yeeeehaaaa.
Also moved the winch solenoid mount and relocated the window washer bottle. everything is starting to fit nicely, even the wiring is starting to look better. not going to wrap the wiring with insul tape as it just makes fault finding hard and looks crap after a while.
Nivapulledout
starting to look more organized. air box and snorkle will have to come later, but dont think I will be fording any deeper than 1.3m this summer.
Biggest battery I could fit in. Should be up to the task.
modify std battery tray with some angle to bracket the base of battery.
some bolts and a top brace finish off the battery mounting system. God I love angle iron.(love my welder as well ha ha)
that is all for now, more wiring tomorrow and then I should be finished most of the electrics. then I need to get stuck into the box section sills and wheel arch cut. then I should be all set for the thurs appointment with the cert guy.
tomsoffroad
Flopsie
Post by tomsoffroad »
What a cool build. Never had much to do with Ladas but they have a cool shape.
Turbo sounds wicked on ya start up vid 8)
