K&N apolo cold air closed system
Trying to find a air box to use when I fit a turbo to a TD42. Was looking for a ZD30 air box but too hard to find. So I found this it ses that it is rated to 350hp on a turbo engine. Don't think I will have more than 350hp even with fuel wound up. Whats peoples thoughts on this product? There about $400 with filter. Probably could get a better one custom made for that price?
Cheers Simon
http://www.knfilters.com/universal/apollo.htm
Cheers Simon
GU patrol 35s ect.
Re: K&N apolo cold air closed system
i have had one on my saf for 5mths now,mine is just behind passenger headlight ,3inch snorkel straight onto k&n then into turbo,goes good,i did use a surf airfilter box wiv a few mods done to it,thats expensive thou where else have you tried??,got mine from repco of all places, do knw theres heaps on ebay in oz
vince
vince
forget horse power ratings when dealing with diesels.
the main thing is sheer size.
i'm not a fan of k&n on diesels. i would find something off a factory turbo diesel that has more power than what your aiming for. don't forget trucks. they often have good air filter setups.
also crowds like donaldson make good sized air filter encloses.
the problem with smallish ones is because a diesel consumes so much air they can fill with dust very quickly.
- Crash bandicoot
you want an airfilter that will outflow a K&N try one from a tractor.
there designed for massive airflow.
i think you will find tractor ones are on the small size due to space constraints. but if the tractor motor is big enough the filter will still be big enough.
trucks are often easier because they often have a bit more room to fit a big filter.
toominator
- Bush Crasher
What area do you have available?
Can have a look at work tomorrow and check out what size donaldson enclosures would suit. Off the top of my head I'm nearly certain it'll work out alot cheaper than the K&N one you're looking at too.
Will be easier getting a new one that fits your requirements rather than getting a second hand one out of another vehicle and having to modify it.
PigFmr wrote:i have had one on my saf for 5mths now,mine is just behind passenger headlight ,3inch snorkel straight onto k&n then into turbo,goes good,i did use a surf airfilter box wiv a few mods done to it,thats expensive thou where else have you tried??,got mine from repco of all places, do knw theres heaps on ebay in oz
vince
Have tried finding a ZD30 one but there elusive. I might have to have a look at yours some day.(just joining North canterbury club). Did you have to move a battery? Will try ebay. I am happy about using a K&N always have its this apolo thing I am uncertain about.
toominator wrote:What area do you have available?
Have a reasonable amount of room Its to fit a TD42 soon TD42+T
That would be great never heard of donaldson will get back to you with the room I have to work with.
tweake wrote:forget horse power ratings when dealing with diesels.
Too hard to find a ZD30 one sounds like a donaldson enclosure could be the go.
Cheers Simon
GU patrol 35s ect.
i will post a pic up if you want,i do knw a few guys running these aint had a problem yet,to be honest there aint alot a room in there to place a air filter really,this is my best option and it seals fine and you cant put a price a good sealed air box well thats my view
vince
vince
was that you that came on wednesday nite ?? to club meeting meet you outside
vince
vince
PigFmr wrote:i will post a pic up if you want,i do knw a few guys running these aint had a problem yet,to be honest there aint alot a room in there to place a air filter really,this is my best option and it seals fine and you cant put a price a good sealed air box well thats my view
vince
That would be great if you put up a pic. I agree thats why I am spending the time and money to get it right. Really well sealed and breathes easy. Yeah thats the one the newbie at the last meet.
Cheers Simon
GU patrol 35s ect.
one of the better air filter setups i have seen.
tweake wrote:one of the better air filter setups i have seen.
Nice very tidy!. Trying not to move battery though as you said thats one of the better air box setups I have seen.
GU patrol 35s ect.
This is what I'll be running in the future.....
http://cgi.ebay.com.au/NISSAN-PATROL-HI ... 2eb31c291c
DaveM wrote:This is what I'll be running in the future.....
Thanks Dave was about to spend $450 on a new factory ZD30 one.
GU patrol 35s ect.
That looks similar to the Prado 2lte filter setup, may be an option if avaliable 2nd hand?
thats no different to a surf airbox that i have used wiv a mod to the inlet and outlet made it 3inch in and out
vince
Tweake what air box is that off its not a donaldson enclosure is it?
GU patrol 35s ect.
i can't remember. search patrol4x4.com there is a post on it. heaps of threads on big air filter setups.
- flyingbrick
Mud Hog wrote:Trying to find a air box to use when I fit a turbo to a TD42. Was looking for a ZD30 air box but too hard to find. So I found this it ses that it is rated to 350hp on a turbo engine. Don't think I will have more than 350hp even with fuel wound up. Whats peoples thoughts on this product? There about $400 with filter. Probably could get a better one custom made for that price?
Cheers Simon
there are very similar setups on trademe for much much much cheaper.
http://www.trademe.co.nz/Trade-Me-Motor ... 216889.htm see.. All you need now is the hose.
flyingbrick wrote:Mud Hog wrote:Trying to find a air box to use when I fit a turbo to a TD42. Was looking for a ZD30 air box but too hard to find. So I found this it ses that it is rated to 350hp on a turbo engine. Don't think I will have more than 350hp even with fuel wound up. Whats peoples thoughts on this product? There about $400 with filter. Probably could get a better one custom made for that price?
Cheers Simon
cheaper.
they are way different ,they are not inclosed at all ,be ok if truck never goes offroad
PigFmr wrote:
Is that yours? Was about to use a Isuzu one but looks like thats an easier fit.
GU patrol 35s ect.
Mud Hog wrote:PigFmr wrote:[
yep thats my setup
vince
