oldyella wrote:I wasn't sure what to do with the air conditioning pipes while I'm not using them. Further down the track I was thinking about on board air but can i just cut them back a stick a bolts with hose clamps in the rubber pipes for the mean time or will that upset the pump?
And that's about all for the meantime...
shove a bolt up the hose and clamp it off, the pump will not run unless you put power to the magnetic clutch on the front
Pedro
