I have a set of coil springs from a GQ Safari sitting in the shed and was wanting to know if they would be a direct swap into a Terrano? I have had a search around on the internet but had no luck.
Thanks, Matt
Safari springs into Terrano
Re: Safari springs into Terrano
No, they wont fit. diameter is way different
Thanks mate, off to autoline it is then.
meatc wrote:No, they wont fit. diameter is way different
Yeah, as he said ^^^^^
I have a bit of nylon bar big enough to make some spacers out of if you want.
You just need a lathe.
Will post a pick.
Paid about $50 for it.
A couple of bottles of wine and it is anybodies
It is, 148mm in dia X195mm long,
Someone offer me something for it and take it away
would that be just as good as getting 2" lift springs?
