Hi All,
As the title says - I'm after a 89 Samurai rear diff. If anyone has one of knows where I can get one it would be much appreciated.
Thanks,
Grunta
After a Samurai Rear Diff
Re: After a Samurai Rear Diff
There is a crown and pinion on trademe for cheap at the moment if you want to rebuild yours -- I bought his front one for a spare, he still has the rear on there.
Hey,
I see there is one there. I was hoping for a complete diff head - take old one out, put new one in
I did the pinion nut up instead of taking it off in a rush when I had a tyre fleet truck around (pinion seal change) - so I believe i've probably knackerd the crush sleeve. Still driving ok, bit whiny though. I use it for hunting so I don't want to get to the middle of nowhere and have the diff give out on me. And i'm not in a financial position to get the diff rebuilt either so hence why I was hoping just to buy a second hand one a swap them around but a samurai diff is proving hard to find
Grunta
Grunta
- You Get That
Ive got a few samuri diff heads at home what ratio you after?
Also a set of complete sj413 diffs(probley not what your looking for)
Where are you?
Where are you?
Addicted to suzukis....
If it hasn't been driven with play in the pinion shaft, the gear set is probably OK. If you end up replacing it, I might be interested in buying it off you -- as you say, the samurai ones are mildly interesting to get your hands on, and I tend to be hard on them!
I'll let you know how it goes Hedgeboar.
thanks,
Grunta
thanks,
Grunta
