TOYOTA OEM PARTS
wjw
TOYOTA OEM PARTS
Post by wjw »
Hi All,
As no one seems to have the parts I need in NZ and Toyota are a rip off, I'm looking to place an order with a Japanese Toyota Parts dealer. I have pricing etc for what I need, but 1/3 of the total cost is shipping. So if anyone needs anything small. Let me know and I'll work out costs. Would need cash up front. You'll need to give me the Toyota part number, you should be able to find it here:
http://www.toyodiy.com/parts/
To give you an idea of costs:
68141-60010 Run, Front Door Glass, LH 3,890 Yen
68151-60010 Run, Front Door Glass, RH 3,890 Yen
68142-60010 Run, Rear Door Glass, RH 3,685 Yen
68152-60010 Run, Rear Door Glass LH 3,685 Yen
69277-60010-06 Bezel Front Door Inside RH 530 Yen
69051-60060 Cylinder and Key Set Lock RH 10,120 Yen
EMS Runs 14,000 Yen to your nearest post office in Christ Church
The first item works out at $65 NZD, adding freight costs makes it $99 add GST $115. Cost from NZ Dealer was $185 + GST.
I will divide the total shipping cost up based on the VALUE of the item.
Bill
Who knew Prados could fly?
Andrew1706
Re: TOYOTA OEM PARTS
Post by Andrew1706 »
When are you planning on doing this?
keen on some radius arm thingy bushes if cheap enough ... will pm ya the part nos
tweake
Post by tweake »
i'm after a gasket 15785-54010 for oil cooler housing, IF you can still get them.
UBZ
Post by UBZ »
Im After the following Stupid parts for the Surf.
45292-35060 / Seal ,Main Shaft Lower Dust
33555-60030 / Boot , Shift lever
33505-35020 / Seat Sub-Assy, Shift lever
33506-60030 / Retainer Sub-Assy , Control Shift lever
33548-31010 / Bush, NO.1, Shift lever
Local toyota dealer didn't even want to get them in for me. :evil:
wjw
Post by wjw »
Planning on ordering early next week. Jerry if you can flick me the part nos asap, I'll get the whole lot priced.
Bill
wjw
Post by wjw »
I've sent the list off for pricing, has to go now so i get it back before I go to bed. Sorry Jerry.
sorry been at work :roll:
wjw
Post by wjw »
Jerry wrote:sorry been at work :roll:
he hasnt replied yet so you still have time...quick quick :)
48702-60020 2 per arm x4 assuming the front are the back as the same
Also the other end of the arm
48764-60020 2 per end? x 4
http://www.toyodiy.com/parts/p_J_1989_T ... _4804.html
wjw
Post by wjw »
I've got all but Jerry's prices:
Code: Select all
Part No & Description                  Yen   Freight   NZD   GST   Total
45292-35060 Seal ,Main Shaft Lower Dust 1,150   631   29.07   4.36   33.43
33555-60030 Boot , Shift lever          350   192   8.85   1.33   10.17
33505-35020 Seat Sub-Assy, Shift lever  460   253   11.63   1.74   13.37
33506-60030 Retainer Sub-Assy , Control   4,420   2427   111.73   16.76   128.49
33548-31010 Bush, NO.1, Shift lever     275   151   6.95   1.04   7.99
15785-54010 Oil Cooler Housing Gasket   330   181   8.34   1.25   9.59
68141-60010 Run, Front Door Glass, LH    3,890   2136   98.34   14.75   113.09
68151-60010 Run, Front Door Glass, RH    3,890   2136   98.34   14.75   113.09
68142-60010 Run, Rear Door Glass, RH    3,685   2023   93.15   13.97   107.13
68152-60010 Run, Rear Door Glass LH    3,685   2023   93.15   13.97   107.13
69277-60010-06 Bezel Front Door Inside    530   291   13.40   2.01   15.41
69051-60060 Cylinder and Key Set Lock    10,120   5556   255.83   38.37   294.20
I checked here for duty:
http://www.customs.govt.nz/importers/Pr ... araTitle04
At worst we should only have to pay GST as duty on car parts is 0%.
Jerry, can I just order your bits? They wont be much looking at this.,
Dace
Post by Dace »
sorry I am late, but is there still time to price this?
68111-89127
Dace
wjw
Post by wjw »
Dace wrote:sorry I am late, but is there still time to price this?
68111-89127
Dace
Theres not time to price it, but my estimation would be 30% discount off toyota retail landed.
I can just add it to the order if you like?
yep go ahead and order them
will make a list for the next order :lol:
wjw
Post by wjw »
Jerry wrote:48702-60020 2 per arm x4 assuming the front are the back as the same
Are they definitely the correct part numbers? couldn't find themo n that diagram?
wjw
Post by wjw »
Still cant see those specific part numbers
stinky
House Hubby
Post by stinky »
if its holding up the order flag it :D (fixing stinkys PC on my day off :roll: )
____________________________
Martin
http://www.wtbs.co.nz
Big
Post by Big »
If you are still gettting an order.. I need
PNC # 36621A
Part #90311-35004..( PTO seal )
If you can fit it in..
Have priced it here at around $46.. LOL but if you can do better thats awesome..
cheers K
just checked again ...
wjw
Post by wjw »
Why couldnt I see that then??? :?
theres a slidy bar on the pic which you needed to slide down to see the rest :roll: :lol: :D
wjw
Post by wjw »
Placed the order last night. Will let you all know when I get delivery dates back
Big
Post by Big »
sounds great wjw.. :D
BTW Jerry what version of EPC are you using..? mine desn't have the slide thingi..lol
fark knows .... the one on the link.... :roll:
wjw
Post by wjw »
www.toyodiy.com/parts they basically hack the most recent Toyota EPC they can get hold of and put it online
wjw
Post by wjw »
Got an update:
Hi Bill,
Just wish to update you.
I have got most of your parts and still waiting for 2 more bits to arrive on the 7th Apr.
Will send them all together when arrived.
Thanks
J Tsuboi
wjw
Post by wjw »
Jerry wrote:just checked again ...
hey Jerry, Jimmie just sent me an update Toyota don't supply those anymore, want me to get the aftermarket ones?
yes please ....
wjw
Post by wjw »
First lot of bits arrived today:
The following are still to come:
Jerry's bush things, although right now the price from Toyota here is cheaper than from JP :-(
Can't work out final price yet as he hasn't charged me????
