wtd suzuki escudo snorkel
For all Suzuki related topics
oljamesyboy
Post by oljamesyboy »
any1 got 1 for sale or know a cheap way of getting/making one?
SP450andLE
Re: wtd suzuki escudo snorkel
Post by SP450andLE »
Pool vacuum hose, depending on what sort of pool it's from. My bro and I have used some from the school where our dad works, and it fits straight onto his Vitara intake, and straight onto the Lada one too.
Whereabouts are you?
lincooln
Post by lincooln »
only works for carb models though. fuel injected is a bit harder to home job it on the cheap. and pool hose looks like arse too. Getting a metal one made up would be the best option
Lubrication Specialist
Lubrication Engineers
Pico42
Post by Pico42 »
If I was to do another one, I would get one done in steel tube. Currently have a Safari one.
oljamesyboy
yea i got a injected one.
might look into making a steel one any ideas where to start would be the 1st snorkel iv made
lneil
Post by lneil »
Exhaust tube works ok and the pattern can be real simple. If you come out towards the rear of the left front guard, in line with the hole in the INNER guard, you just need a 90 degree elbow and the tube can run straight up the line of the A-pillar. We've screwed ours into the A-pillar, given it a slight forward tilt to make the top upright and fitted a snorkel hat.
Connect the steel 90 degree elbow to the air intake with flexible hose, but make sure the joins are tight and well sealed (waterproof).
Return to “Suzuki”
