Castor Wedges?
Castor Wedges?
Need to get hold of some 2 degree castor wedges. These are the things that you fit between your diff and springs to set castor angle. Where can i get some???
Re: Castor Wedges?
Try Bellamy and East . 3654371 or failing that pinch some off Nibby's vehicle, he will never need them
FITZY.
FITZY.
- Bulletproof
Re: Castor Wedges?
H2OLOVA wrote:Need to get hold of some 2 degree castor wedges. These are the things that you fit between your diff and springs to set castor angle. Where can i get some???
If no one on ORE has any, the place that I have found best and always seem to have a good selection are the truck wreckers. Sometimes you just need to cut the sides off with an angle grinder. I know Nelson truck spares have a heap.
Cheers Richard
Never say die, up man and try
Re: Castor Wedges?
Nibbys truck doesn't have any otherwise i would have
Cheers for the help guys
Re: Castor Wedges?
I need some for my cruiser to i was just going to make some but if you find any where that has some let me know
Re: Castor Wedges?
Truck Alignments in Columbia Ave Ch Ch have various sizes.
Re: Castor Wedges?
an old thread i know but serves the purpose... looking for 8-12mm wedges for the back of my landrover... im not sure of angle and have only done rough estimate with ruler. anyone know a place around auckland where i could get some?
Offroad Addiction TV
Re: Castor Wedges?
My best guess would be somewhere that does heavy vehicle wheel alignments.
Re: Castor Wedges?
vincent truck wreckers in wiri
Re: Castor Wedges?
i have tried all around NZ and the best i could come up with was a set from John Bates, which is where i got my first set from, the problem is the in the ID of the centre pin is far too large.
Re: Castor Wedges?
G guy motors in wgtn do them, think they're about 40 bucks
Re: Castor Wedges?
good to know you can get them in NZ. does anyone know anywhere near Auckland?
Re: Castor Wedges?
Theres a place here in hamilton that does them too. Not auckland but a bit closer than wellington.
- ClassicCruiserSpares
- Sausage Shack
Re: Castor Wedges?
Why not get your local enginneer to mill some up to the exact shape and size?
