v6 motor needed
v6 motor needed
just brought a vitara needing work. motor half pulled to bits thought it might b easyer to put a new motor in it instead of tryin to work out what the last person has done and then finding out that there is bits missing.
might be keen on sellin it on as is if was offered the right money
Re: v6 motor needed
saw that one bit more than i wanted to pay by the time i got it to invercargill
Re: v6 motor needed
Keep an eye out for a 2.5 motor too, they fit right in, a bit more pep than the 2L if that's what you have now.
Good luck!
Good luck!
Re: v6 motor needed
sweet what other bits do i need to get it going though. i realy want something i can drop in and make it go. got my real project truck i would rather be spending time on but this was a offer to good to turn down
Re: v6 motor needed
I might have a 2.5 block with a couple of bent rods in it if your interested. You can even hear it running. Supposedly the 2.0 use the same rods so it could be a case of swapping some parts. I probably will need the injectors for it. PM me if your keen.
Re: v6 motor needed
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Holden/Engines/auction-370491971.htm
you said v6!
Re: v6 motor needed
callum007 wrote:http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Holden/Engines/auction-370491971.htm
you said v6!
yea that would work but i already half way through a project like that. just want to get this one going fast.
ok so i found a 2.5 motor complete and cheap but need to know if the loom is the same. and will the computer run it.
Re: v6 motor needed
dont know about the loom but I highly doubt that the 2.0L ECU will work with the 2.5.
Still I have been wrong before (sometimes frequently)
Lubrication Specialist
Lubrication Engineers
Re: v6 motor needed
Supposedly bolt in and use the 2.5 injectors. Google it, its been done a few times.
How much for the motor?
Re: v6 motor needed
churchill wrote:Supposedly bolt in and use the 2.5 injectors. Google it, its been done a few times.
been offered the 2.5 for $300 it got droped and sump broke and few of the other bolt on bits. i think the motor should be ok though.
Re: v6 motor needed
Sharp deal, hope it works out for you. Let me know if you need any parts.
Re: v6 motor needed
ok so got the new h25 motor today and sat it on the ground by the truck that we got, was looking for diffrances in the to as got told i needed to change the IAC. I could not find any diffrances.
the id tag on fire wall says it is a h20 but having a better look at the motor in the truck it is a h25. now the problem i have is that all the motor looks factory as a h25 should but if it ever was a h20 in there the h25 should have some parts from the h20.
(hope this makes sence)
is it posable that they cocked up at factory and put the wrong id plate on.
is there any other difrances between the 2l and the 2.5l trucks that arnt to do do with the motor that i can compare.
Re: v6 motor needed
What year is the car ? Is it the square or round shape ? Why are you panicking ? It sounds like the motors are identical by the sound of it. Why aren't you bolting in the new one and turning the key ? Did I miss something along the way ? Is the new motor the damaged one mentioned above ?
H
H
Re: v6 motor needed
that is what we r going to try. there is a dif between the two and the new bigger motor should not work without changing some bits. acourding to the ausi site that someone gave me the link for.
truck is a 1995
truck is a 1995
Re: v6 motor needed
A factory 2.5 vitara should have the vacuum driven free wheel hubs. There should be a little pump situated on the drivers side of the strut brace and a tube going into the bottom of your front diff. They usually have ABS and airbags as well.
Chassis number should be T*61 for a 2.5. Mines a Mazda badged one so the Chassis number is TJ61W
I think the key things to use from the existing engine are the injectors and MAP sensor. I would basically just change the block, this is assuming the existing 2.5 ran correctly in the first place.
http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/29174-h25a-into-97-vitara-2.html
Whats your chassis number and what colour injectors do you have on each engine?
Let me know if you have any spare con rods from the old 2.5.
