SR20DET in a vitara. has any one done it before
For all Suzuki related topics
junkie
Stropper
Post by junkie »
im looking at puting a SR20DET out of a s15 silvia in to my vitara has anyone done it before . ive got no problem with wiring or engine mounts. but is it worth making an adaptor. or will i get more bag for buk if i go fuel injected 1600 with a garrett T28 turbo and worked cam? wat do you reckon?
lincooln
Re: SR20DET in a vitara. has any one done it before
Post by lincooln »
Well there was a guy who was selling one on TradeMe a little while ago. I would think it would destroy cv's whenever you put your foot down. turbo wise I looked at it and talked to a few people and they said they had some fairly serious problems, cant for the life of me remember them now.
oh and cam wise you cant go past mild as in the g16's the rockers dont like it. Well thats what a guy in my club said happens, after he tried it on his own zuk. (his job is cam grinding)
Lubrication Specialist
Lubrication Engineers
pradon35s
Post by pradon35s »
sr20dets dont like old oil or not having regular oil change, the oil feeds to lube the cams block up and you can have cam issues.
bearing in mind my flatmate has one in his Silvia drift car that only goes on the track and has had a hiding non stop for last sort of 4 years. in my mind bloody good engines.
but maybe not for a 4wd..
lincooln
Post by lincooln »
Basically yes you need to keep the oil very clean and fresh to prevent blockages. the only thing is that it would probably be to powerful for the Suzuki drive-line to handle it. I standard spec sr20det might be ok if you keep your right foot light. But just be prepared to fix CV's all the time.
Swamped
Post by Swamped »
You coulda just bought the one that was on trademe recently. He ended up trading a terrano for it :lol: Pretty much the exact specs your after. If you didn't sas it it would more than likely eat cv's as already mentioned. My mates one was ok but was just driven sensibly offroad. Was a weapon on the road. Ran 31 buckshots and had a heap of power. I think he started with a T25 and ended up with a T28 but had stock cams.
Its a snug fit in the engine bay too.
meatc
Post by meatc »
I have a supercharged ca18de in my 413 on hilux axles, and have busted cvs in that.
Know a guy running a turbo 1600 zuk motor in his vit and it eats cvs for breakfast lunch and dinner, got better when he had rings made to go round the outer cv, then it started on diffs.
Cleary
Post by Cleary »
Vitara's have weak front diff mounts and weak CV's. 150kw plus is very likely to eat them for breakfast.
I had an SR20DET in my E class rally truck with prado diffs and CV's and never broke anything, but that's a whole different proposition.
SR20's are common engines in the 4 cylinder classes in trialling. They produce good torque and seem to last OK. You do need to keep the oil clean. Another option is to drill out the oil feed holes that lube the cam lobes, as this reduces the chance of blockages.
TD power
Post by TD power »
its like most things suzuki as soon as u put a nissan in them you never touch the engs but a stuff everything else
mud_slinger
Post by mud_slinger »
i would'nt drill out the the oil lines in the head, as this will upset the oil pressure and if the holes are to big the oil wont make it to the last squirter which will give you a nice cam grind or a run bearing.
needs more curry
0272593533
junkie
Stropper
Post by junkie »
thanks for the advice. i just brought a full injected motor on a 150 k and scored a t28 garret turbo. luks like itz gna be the turbz 1.6 happing sounds like the better option
Lynx
Post by Lynx »
junkie wrote:thanks for the advice. i just brought a full injected motor on a 150 k and scored a t28 garret turbo. luks like itz gna be the turbz 1.6 happing sounds like the better option
Chur bro, u gunna put da turbz on ya zuki, fukn fully sick mannnnnnnnnn
lincooln
Post by lincooln »
take pics and so on of the manifolds if you do go ahead with the turbo.
good luck
Return to “Suzuki”
