Niva 4.3 front diff needed.
Talking to John (the Guy who run's a niva in nationals), he's after a 4.3 ratio front diff for his Niva, Anyone got one they are willing to part with to help him represent the lada comunity???
He's up hamilton way, but sure we can sort out ORE courier or something if your in another part of NZ??
PM me for his details if you can help...
I've invited him to join the forum too, hopefuly he'll be along soon...
It's just more fun in a lada !!
Re: Niva 4.3 front diff needed.
Hmm... I wonder how many of those are still around. Can't be too common...
ive got two going for 500 with two ladas attached 200 more for 31" maxxis mudders on wide alloy rims goes hard as
ethan loves toyota wrote:ive got two going for 500 with two ladas attached 200 more for 31" maxxis mudders on wide alloy rims goes hard as
What condition are the muddies in?
- Nivapulledout
I would but my spare is 4.1 bugger
still got heaps of tread
ethan loves toyota wrote:still got heaps of tread
Whereabouts are you?
I assume you've tried Gee's? Pretty sure he could get them easily enough last time I asked (but pricey iirc).
I've been looking out for some 4.3s for a while and they only come up occasionally (unless of course you want to buy whole cars).
christchurch mate
if you want a 4.3 ratio try and find a 2104 lada car.apparently they bolt straight in.
The entire range of ratios are a straight swap between the rear drive cars and the Nivas.
Regards,
Regards,
Hi all i think i have a 4.3 an a 4.1
Hi guy's, Thanks for your reply's,
sorry, I've been reading these as they come up but not been round enough to reply to each individually, Using diff for lada car isn't much help for John, it's a front diff he's after...
Thanks Patrick, I'll email the guy's info...
I thougth John might've joined up by now, but haven't seen him on here...
ladanut wrote:Hi all i think i have a 4.3 an a 4.1
Rear diff assembly fits in the front. Same thing.
Regards,
Hoodoo
Regards,
Hoodoo
Hoodoo wrote:Rear diff assembly fits in the front. Same thing.
Regards,
Hoodoo
He's having problems with cracking mounts and casings, (also not allowed to do steelcase front diff in the class he's currently in...)
No, didn't mean the case - the innards all transfer from rear to front, and vice-versa. Is he allowed to alloy weld on strengthening ribs? They probably break in much the same place every time?
Regards,
Hoodoo.
Regards,
Hoodoo.
- Nivapulledout
I think hoodoo is saying is he allowed to fill all the gaps in between the ribs with alloy weld as this adds a lot of strength to the casing.
No he cant. In A class you can modify inside axle housings/diffs (ie run aftermarket axles/cvs and change gear ratios) but cannot strengthen externally.
Thanks for your help guys, nope he can't alter the housing in any way, last time I talked to him he was trying to make up a cradle to support it a bit better...
I'll cheak with him how he got on and see if I can get some pics of what he achieved.
Various people have made cradles that link between the front crossmember and the anti-roll bar, usually when fitting different engines. I think Baxter has details on his site?
Regards,
Regards,
