Had really good air flow, and used f all feul ay
If you got a full 3inch exhaust than cut a new hole in your air box andweld3inch pipe on it u will see gains in power and fuel ecomany.
The terrano air boxs are really to small for the air they need so its a good up grade to do it like that
Terrano snorkel design
- KIWI_TERRANO
Re: Terrano snorkel design
u13turbo wrote:kiwipete wrote:u13turbo wrote:So i have finally decided that im going to get one of the prebent snorkels from autobend. Just wondering, do they come with and fittings? or mounts? or just the pipe and thats it?
Check out my post when I did my snorkle, the Autobend is just the bent pipe, nothing else. I think I have some of the flexi hose left over if you need some for the airbox.
Feel free to come and have a look at mine first if you like.
Where in Chch do you live mate? I dont think i'll beable to make it out to yours before friday, But I will take a look at your pics of how you mounted it, and for my diff breathers, could i just plumb them into the intake somewhere?
PM me for address details.
I have only extended the rear breather, put a tube on the diff and ran it through a bung in the floor and then up inside the the rear seatbelt mounts on the door pillar area. The front ones all end up high on the firewall so no issues there.
Ph 0212078472
Ph 0212078472
