rear trailing arms
rear trailing arms
found out can get chrome moly at $11.85 a foot and have a spare rear arm so going to made some chrome moly ones should just cost about $145 a arm to make, sweet
Re: rear trailing arms
Where are you getting chromemoly that cheap???
come on let us all know
let me see if it a true price,
then i will share
1'' 1/4 tube heaviest wall they had $16.oo odd a foot still happy
1 1/4'' would be a little small for a safari wouldn't it?
well, same size as the stock for now , the joys of being a welder, can change anything ,with time
Hi,
What is the wall thickness, even though CrMo is about twice the yeild strength of Mild steel pipe, because it is thinner it maybe more prone to impact damage causing a dent such that it may then bend. Also think 1 1/4" sounds quite small.
Tim
Tim
the std arms are about 1.8-2.0mm wall thickness,they bend/ break very easy.Even if the CrMo is only 3-4mm it would have to be a heap stronger?
If I did one again(safari) I would make the arms much longer(approx 300mm)needs new pick up/cert etc but would be worth the effert ,helps stop bounce esp when climbing.
Can buy a long arm kit from Oz,most Kiwi's would just make it them self or get a mate do it.
post the pics Coxsy when you get it done
Shane
Shane
Shane wrote:the std arms are about 1.8-2.0mm wall thickness,they bend/ break very easy.Even if the CrMo is only 3-4mm it would have to be a heap stronger?
post the pics Coxsy when you get it done![]()
Shane
Unfortunately, the long arm kits are only available for the LWB, as there appears to be no room on the shorties chassis for moving the mounts foward
going to add a strip of flat to the bar as superior do to add strenght , jig made up at work so 16mm longer is not a problem have new bushes here too,
just to make it fun overtime needs to be done, so if i get time will do one up for a sample see how we go
its a bugger when work gets in the way
DaveM wrote:Shane wrote:the std arms are about 1.8-2.0mm wall thickness,they bend/ break very easy.Even if the CrMo is only 3-4mm it would have to be a heap stronger?
Shane
Ok, I didnt know that
as you were...
size of this moly is 31mmx3mm wall it'll do fine
15 mins of work today all tacked up, will get the nice tig welder guys to weld it,
- muddyhilux
that looks like a nice bit of work for 15mins mate,good effort
some idiot sat and ate his lunch and forgot about them, ME
still got to add the flat bar to the lenght yet or maybe not
- muddyhilux
as for flat bar I've never seen them on trail arms but I wouldn't be surprised if people did it,would definitely add strength and if you've got the space I wouldn't see why not
